Old 07-13-2014, 09:31 PM   #1
DFlores's Avatar
1968 22' Safari
Gas line protection
I know this was covered a couple of years ago, but has anyone had any experience with spiral hose wrap
Name:	ImageUploadedByAirstream Forums1405308581.464567.jpg
What other options have you used for protecting 3/8" and 1/2" copper tubing
Sent from my iPhone
David & Diane
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 07-14-2014, 03:18 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Mine is almost 40 years old and has traveled tens of thousands of miles and hasn't needed protecting...
I need to replace some valves due to corroding but other than that the line is fine and pretty well protected by mounted tight to the bell pan.
Aaron
WBCCI #XXXX AIR #2495
Old 07-14-2014, 07:58 AM   #3
DFlores's Avatar
1968 22' Safari
Wahoonc, we are setting up a high ground clearance unit
Name:	ImageUploadedByAirstream Forums1405346145.520854.jpg
Trying to avoid issues like bottoming out in a dip and also we want to get a little further off the beaten path, so I thought to try and keep holes out of gas lines.
Sent from my iPhone
David & Diane
DFlores
David & Diana
Old 07-14-2014, 08:17 AM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The instructions for my water heater called for a 3/4" line, so I ran black pipe.
Raised my trailer up 3" too, this really helps to minimize the donkey drag.
Old 07-14-2014, 08:48 AM   #5
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I would recommend the black pipe as well for durability.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 07-14-2014, 08:52 AM   #6
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
J.Morgan, what do you mean by "donkey drag?"
Thanks, Bob
Bob Martel
WBCCI# 5766
Old 07-14-2014, 11:14 AM   #7
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
Dragging the rear end of the trailer through a deep dip or steep driveway.
Bruce
Old 07-14-2014, 11:24 AM   #8
DFlores's Avatar
1968 22' Safari
Thanks for the recommendations, but I already bought and started to install the copper tubing, wanted to run lines thru floor before installing cabinets. The spiral wrap is expensive, was looking for a cheaper alternative.
DFlores
David & Diana
Old 07-14-2014, 11:27 AM   #9
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
If you are talking about the propane lines, I wrapped them with vinyl tubing. It is available at any big box store selling hardware. I split it along one side and clamped it on with hose clamps. There are also clamps holding the copper and I loosened those to hold the vinyl too. If anything hits the copper pipe, I hope the vinyl will absorb and spread the force.
Gene
Gene
Old 07-15-2014, 06:12 PM   #10
DFlores's Avatar
1968 22' Safari
Has anyone used regular garden hose?
DFlores
David & Diana
Need pictures of gas line for Magic Chief oven gas connection dghaas General Repair Forum 1 01-30-2009 09:04 PM
Line-X or Rhinoliner protection Mike S Rock Guards, Segment & Window Protectors 14 09-21-2008 06:01 PM
gas line to water heater bken Water Heaters, Filters & Pumps 0 05-03-2003 08:11 PM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 03:52 AM
Propane and Electrical Line Protection Tamara Electrical - Systems, Generators, Batteries & Solar 7 06-27-2002 09:42 PM
