Old 04-19-2016, 12:49 PM   #1
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Gas line emergency repair.
Last fall I ran over a piece of road debris that bounced up and punctured the gas line that supplies my furnace.
Upon finding the hole at the campground I made a trip to WalMart and bought some five minute epoxy and some silicone tape...
I just got around to making a permanent repair.... My patch job remained 100% air tight even after the silicone tape was removed.
Thoughts? Click image for larger version
Name:	ImageUploadedByAirstream Forums1461091737.952363.jpg
ID:	261016Click image for larger version
Name:	ImageUploadedByAirstream Forums1461091750.225398.jpg
ID:	261017Click image for larger version
Name:	ImageUploadedByAirstream Forums1461091763.282461.jpg
I am thinking that maybe I should have just left my temporary repair as permanent.
Superat stultitia.
Old 04-19-2016, 01:13 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Personally, I would replace the punctured section of copper tubing with a new section, and forget the patch job. But that's just me.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-19-2016, 01:32 PM   #3
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
I don't think that's a good plan - in fact I would replace the entire line - ez to do
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 04-19-2016, 02:14 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
The section is already replaced.
But I think the repair would have lasted years or decades.....
If I had come on here asking advise before affecting my epoxy and silicone tape repair, I wonder how my idea would have polled?
Superat stultitia.
Old 04-19-2016, 02:29 PM   #5
Long Island , New York
Thumbs down . . .
OTRA15 is online now   Reply With Quote
Old 04-19-2016, 02:41 PM   #6
Ken J's Avatar
Durango , Colorado
Images: 14
Well replace again - I doubt you would get much support for your plan - now if you were asking about 1 ton trucks vs mini vans you would get support for either lol !!!!
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 04-19-2016, 02:44 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Well, it was cold that night, we needed heat and a hot shower....
Elizabeth liked my repair. It served us for even a few weeks beyond repair night...
There is a reason why I seldom post about something before I actually do it... (Which MIGHT similarly include my permanent repair)
Superat stultitia.
Old 04-19-2016, 03:17 PM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Superat stultitia.
After reading your post, I would be inclined to try the same patch if I were in your situation.
Quoting you "Illegitimi non carborundum"
Suum cuique.
add edit: most people discouragingly commenting on your patching method probably do not realize the small amount of pressure in the secondary gas line. A 14" water column =~0.5 psi
Old 04-19-2016, 03:31 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Yea, the pressure is almost like nothing. High flow, low pressure.
"Suum cuique."
Yep!!
Superat stultitia.
Old 04-19-2016, 03:37 PM   #10
Ken J's Avatar
Durango , Colorado
Images: 14
Well - I'm totally aware of the pressure - actually should be set at 11 column inches :-) - anyway - you did ask what we thought
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 04-19-2016, 03:40 PM   #11
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I did ask, I just thought it might be a fun conversation!
Superat stultitia.
Old 04-19-2016, 03:45 PM   #12
Ken J's Avatar
Durango , Colorado
Images: 14
Oh - always checks for leak on repairs such as this - a lighted match works best
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 04-19-2016, 03:47 PM   #13
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I wrapped all my lines with the split plastic electric wire conduit, mostly to keep it from being beat to death from road debris and small rocks, so far it is working...
Old 04-19-2016, 03:50 PM   #14
I discouragingly commented because it's not in compliance with NFPA 1192, the RV Standard wherein propane plumbing is covered. The patch may work. It may not. Only time will tell. But whether it works or not, it's not in compliance with the RV Standard.
The OP is not obligated to follow NFPA 1192— or even to have read it— since he did the work to his own trailer. If he wants to trust a non-compliant patch on a propane line, that's on him. Our opinions on the matter don't matter.
WBCCI #1105
TAC LA-4
Clipper, Emergency Exit, Land Yacht, Emergency Ladder masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 9 03-05-2015 10:34 PM
Gas line repAir airtwins LP Gas, Piping, Tanks & Regulators 11 10-31-2012 09:50 PM
Gas line repair at front hitch-help needed Jeremy9107 LP Gas, Piping, Tanks & Regulators 2 09-19-2012 11:05 AM
Need pictures of gas line for Magic Chief oven gas connection dghaas General Repair Forum 1 01-30-2009 09:04 PM
HELP Emergency oil line busted! Astrodokk Airstream Motorhome Forums 8 10-30-2003 07:01 AM
