Old 12-13-2009, 10:39 AM   #1
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
Gas Line and PEX is this setup correct?
Replacing the copper w/ Pex and ran into a questionable issue. It appears that the water line and gas line intersect in a "T". Coming from HW heater to the gas line to the water line. Is this an unusual setup? Anything you would change ? Thanks.
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline   Reply With Quote
Old 12-13-2009, 10:58 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
There is no way the gas and water lines will ever connect to one another. The water lines on a hot water heater come off the back of the heater while the gas line will connect to the front, accessible from the outside of the trailer at the heater door.
If you are replacing water line with Pex that is fine but do not replace the gas line with anything other than copper. You can use flexible copper line to replace the older hard copper but that is the limit when it comes to copper.
Study the lines shown in your picture some more. Not sure where that Tee goes but it is not to the gas.
2004 Excursion 4x4
Old 12-13-2009, 11:06 AM   #3
65CV's Avatar
Western , Massachusetts
cold water
It has to be the cold water feed to the hot water heater. If it hooks to the gas lines at all, it was a very stupid mistake on the part of a previous owner.
Please be VERY careful with propane. A second, qualified opinion could save lives.
John
65CV is offline   Reply With Quote
Old 12-13-2009, 01:34 PM   #4
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
If your repiping the hot water tank, why not put in a hot water bypass. It will make it easier to witerize.
Bigventure is offline   Reply With Quote
Old 12-13-2009, 02:01 PM   #5
Images: 59
Perhaps the PO was one of those guys experimenting with water4gas?
markdoane is online now   Reply With Quote
Old 12-13-2009, 03:19 PM   #6
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
Looking at the last pic, the line coming down into the Tee are both gas. There is a flex product for gas lines but i would stay with the copper. Copper is tuffer, and it appears on the pic with the gas line they used flexible (soft) copper line to help route it. It most likely feeds from the rigid copper (the Tee line)
Al
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
--Mark Twain
Alwhisman is offline   Reply With Quote
Old 12-13-2009, 03:26 PM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It's difficult for me to tell what is what from your pictures, but the gas and water should never cross.
The gas lines should run under the trailer and go up through the floor directly to the device they are attached to. You should see a shutoff valve under the trailer for most or all of the gas devices. It should be fairly simple to follow these where they come through the floor.
The water lines should all be above the floor except where they attach to the city water connector, the water tank and any drain lines.
Richard
Old 12-13-2009, 08:22 PM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Diagram
Here is a diagram from the 72 Service Manual that may help - our 71 was the same except the outside water faucet was added at a later date. So you may or may not have part 14 and 28 and the line leading to it.
The water heater when back together should look something like this, if you use the flex lines and install the bypass kit.
Old 12-13-2009, 09:15 PM   #9
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
The gas line I think would go in up front, with the fitting actually accessible only from outside the trailer. That looks like a cold water line. All gas lines would be under the trailer, below the belly pan. I'm sure some looking at there and you'll see where the gas line comes up through the floor and into the water heater. That big loop in the rear would be where the water regulator was stock, has been removed, so thats why the loop. That loop also looks to tie into the low point drain (red handled valve by the black tank valve).
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
gas, pex, replumb, waterlines
kink in gas line dluker LP Gas, Piping, Tanks & Regulators 2 08-28-2009 07:06 PM
Need pictures of gas line for Magic Chief oven gas connection dghaas General Repair Forum 1 01-30-2009 09:04 PM
Pex line and flair-it fittings question Frieberg Plumbing - Systems & Fixtures 3 10-13-2008 07:40 PM
Rubber Gas Line Sundance LP Gas, Piping, Tanks & Regulators 4 07-13-2007 05:06 PM
LP gas line question 63air LP Gas, Piping, Tanks & Regulators 5 01-21-2007 09:41 PM
