Old 08-28-2015, 10:28 AM   #1
1968 26' Overlander
Portland , Oregon
Gas leak at oven pilot valve - 68' Magic Chef
My original Magic Chef started leaking gas at the pilot valve. I tracked down the leak but am unable to loosen the fitting so I can put yellow Teflon on and snug everything up again to make it leak free.
Advice offered for freeing the seized fitting would be helpful. So far used a healthy dose of PB Blaster, but no luck. Force isn't helping either
It is the larger fitting to the right in the photos. Thanks!! Photos are here: https://goo.gl/photos/7NMHHkefvPS1WQX36
AirstreamPDX is offline   Reply With Quote
Old 08-28-2015, 11:24 AM   #2
Mission , Texas
The brass FPT to flare fitting on the right side of the valve?
I would use either a large crescent wrench or a pipe wrench on the valve (it won't fit perfect, but the idea is to keep the valve from moving), and an open end (preferred) or crescent on the fitting, loosen - if it won't budge, try tightening then loosen, if it still won't budge heat it with a blow dryer or heat gun (but not a torch for obvious reasons) and try again.
Before the days of teflon tape some pipe joint compounds were more like epoxy as they got older and almost impossible to move.
Longer wrench handles, more leverage, easier to move.
Never use anything on flare joints.
nrgtrakr is offline   Reply With Quote
Oven pilot light problem, '79 Magic Chef blickcd Stoves, Ovens & Microwaves 10 09-28-2013 12:31 PM
Weak oven pilot - was trouble with Magic Chef '79 blickcd Stoves, Ovens & Microwaves 3 06-29-2009 10:03 AM
Magic Chef Oven Pilot flames/blows out HansenClan LP Gas, Piping, Tanks & Regulators 3 09-22-2008 10:28 PM
Looking for pictures of early 60's Magic Chef oven Pilot assembly volvophile Stoves, Ovens & Microwaves 9 07-04-2007 05:33 PM
Magic Chef Oven pilot sammamishsafari Stoves, Ovens & Microwaves 2 08-22-2003 08:17 PM
