Old 03-27-2011, 11:20 AM   #15
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
Don't be alarmed if your furnace fails to ignite or your gas water heater pilot won't light once you get everything connected. I've found it takes a while for the air to purge out of the lines, especially for the w/h which is at the end of the line in the rear.
4RXLA is offline   Reply With Quote
Old 03-28-2011, 10:01 AM   #16
Wise Elder
Jammer's Avatar
2010 30' Classic
I guess my official advice is to get someone who's done it before to show you how to check everything and light the appliances. People get burned trying to light pilot lights if they don't know how, which is one of the reasons they've become so rare.
Old 03-28-2011, 02:18 PM   #17
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If yours has the original equipment. I doubt that it has "auto" light.
The furnace has a "standing" pilot that you have to light by hand. There should be instructions on the door or side of it as to how to start. You need to check out the plenum and combustion chamber on these old units; it could be rusted out and be a real death trap.
I've attached some photos of my refer with the operating procedure. There are a couple of ways to go about it. From the front (top photo) and from the outside (2nd and 3rd photo) if you can't make it happen from the front. In one photo, I'm holding the valve open and in the other I'm lighting the pilot. The refer must be level to work. Put a level on the floor of the freezer and check it in both directions. Level the trailer accordingly. Don't use the levels on the outside of the trailer, they are not accurate enough.
The water heater (bottom photo) has a standing pilot. There will be a knob with 3 positions. "OFF-PILOT-ON" , the blue one next to the red one in the bottom photo. To light the pilot, put it (the blue knob)in the pilot position and push the red knob in while you light the pilot. Keep the knob in to get the thermo couple hot enough to open the gas valve. Meaning the pilot stays lit after you release the red knob. Once the pilot is lit, rotate the gas valve to the "ON" position. DO NOT light the water heater if it is not full of water.
Start by turning the valve on top of the tank to open. Then follow the gas lines under the trailer with a spray bottle of soapy water; spray every joint and fitting on all lines and look for soap bubbles, if there are bubbles you have a leak that needs attention.. There will be branch lines off of the main line to each appliance; each of these branch lines (check these lines for leaks as well all the way to where they enter the appliance) will have a valve to shut the gas off to each appliance. Because the lines will be full of air it will take time to purge the air. Start with the stove top. Open the outside valve under the trailer that feeds the stove. Then turn on one of the top burners, listen for the hiss of gas; if you hear it start trying to light the burner with your BBQ lighter. Once lit, leave it burning for a few minutes to purge the line of air. In the mean time you can light the remainder of the stove top burners. Some stoves have a valve under the lid to turn on the gas.
Again; it will take quite a while to purge the air from the lines, especially to the refer and water heater since the pilots don't consume much gas. So have patience.
ID:	125565   Click image for larger version
ID:	125567   Click image for larger version
Name:	Water heater.jpg
Ugh! It's time for the roof. DougZ Roof 7 02-03-2011 06:56 PM
Gas price increase Rollerboy On The Road... 21 01-15-2011 07:48 PM
How can I fill my US Ali gas bottles with LPG in the UK??? shinny67 LP Gas, Piping, Tanks & Regulators 7 01-14-2011 09:42 AM
Factory hooked up gas detector wrong! lsrart1 General Repair Forum 6 01-13-2011 01:51 PM
