Old 05-28-2015, 11:49 AM   #1
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
Furnace Vent - How Hot? And Ducting?
Hello,
I'm in the process of renovating our '79 Excella and have a question about venting the exhaust from our furnace...
How hot does the exhaust actually get?
During the renovation, I moved the furnace to a location where the exhaust vent from the furnace doesn't line up with the outside wall of the trailer, so I need to find suitable ducting that I can route from the furnace exhaust to an outside exhaust port.
Would something like this work?
The description from the website says: "It also is perfect venting and exhaust applications" but I'm not sure if this applies to furnace exhaust applications. Temperature rating is "UL rated operating temperature: -20°F up to 180°F".
Is this safe to use for my furnace application? Don't want to start a fire next time I turn on the heat!
trekerboy is offline   Reply With Quote
Old 05-28-2015, 11:57 AM   #2
1974 Argosy 20
Kooskia , Idaho
No, don't use it. The furnace vent is NOT designed to be changed or extended from the original system that Suburban designed and supplied with it. The internal fan which supplies the combustion air and exhausts the gasses is very carefully set up for a specific type and length of air path.
This is a life and safety issue. Do not modify the original exhaust system.
1988 Furnace Ducting? KF850 Furnaces, Heaters, Fireplaces & Air Conditioning 2 01-08-2015 05:30 AM
Furnace Ducting Design Review - 66 Trade Wind dbj216 Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-08-2014 08:53 AM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
Furnace ducting question? Mrcrowley Winter Living 6 08-26-2011 07:51 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
