Join Airstream Forums Today
Old 12-04-2011, 07:21 PM   #1
2005 16' Safari
Ottawa , Ontario
Furnace has flashing red light !!!
I do not have the proper furnace manual . The furnace on my 16ft Bambi is the small 12000 BTU model 8012-II . Yesterday it seemed to work fine after I charged the battery (no shore power in the storage yard) but I noticed when I turned it down and it went off there was a flashing red light coming from behind a small panel . With the grill off there is a reset/off switch that does not stop the light flashing in either posn.
Today I could not get the furnace to go on but the light kept flashing until I disconnected the battery. There is gas because the range works .
Ideas ?
Peter Housto is offline   Reply With Quote
Old 12-04-2011, 07:46 PM   #2
clancy_boy's Avatar
2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Suburban or Atwood RV Heater?
SUBURBAN MANUAL LINK
http://manuals.adventurerv.net/Subur...ice_Manual.pdf
ATWOOD
http://bryantrv.com/docs2/docs/hflamefurn04.pdf
Gas? If notenough then it won't light without pressure. Stove may light but not as sensitive as the heater to low pressure.
Power? Needs enough voltage and will check - battery low or not on shore power then it will lockout until reset.
Michael, Tina & Layla BZ
1966 17' CARAVEL LUCY
2003 22' INTERNATIONAL CCD DESI
Old 12-04-2011, 08:59 PM   #3
2005 16' Safari
Ottawa , Ontario
Thanks again Clancy . That Atwood manual is what I need. Ithink you may have the answer : Batt or Propane is low . Will check tomorrow. I still can't figure the flashing red LED . It could be a warning that either is low ? Like I said , when the heater was working the light flashed whether it was on or off .
Old 12-04-2011, 10:44 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 59
We have had this happen with our furnace, usually when it has not been used in a while. Try turning your furnace off at the thermostat. Then turn the entire thermostat off with the switch on the bottom of the thermostat. Toggle or push the reset switch on the furnace. Wait a few minutes. Turn the thermostat back on. Try to start the furnace again by setting the thermostat 5 or 10 degrees above the current ambient temp. First the blower will come on then the burner it should try to start ...you'll hear a click-click-click as it tries to start...if it fails it will pause and try again in a minute or so...if it is not successful in starting in 3 attempts, it will stop and shut down and the red light will start flashing.
If you have no success at getting it to start, aside form simply being tempermental, it could be any number of things...a stuck sail switch, low gas pressure or low battery...see what the manual offers in the way of trouble shooting...
TB & Greg - Sadie Cocker & Abbey Schnauzer
AirForums #21900 . Membership Chair, 4C
Unit #3954
Inside AZBambi: AZBambi Décors
Old 12-05-2011, 01:57 AM   #5
2005 19' Safari
Phoenix , Arizona
As others mentioned, low pressure will prevent the furnace from lighting. If you are camping at higher altitudes (in the mountains) and/or in sub-freezing weather, your propane tanks lose pressure as the propane is consumed. A few winters ago, we had to switch to a full tank when the first tank was still almost half full, because the pressure was insufficient for the furnace to light consistently and stay lit. Try switching to the second tank (if it's full); and see if this helps.
Old 12-05-2011, 05:49 PM   #6
2005 16' Safari
Ottawa , Ontario
Thanks to you all . Today the kind folks at Atwood emailed me the proper manual and I read that the flashing red light means: (1) limit switch/airflow problems or (2) Flame sense fault or (3) ignition lockout fault . I am charging the batt. right now and have a new fresh filled gas bottle in place. I am sure it will work .
Old 12-05-2011, 06:50 PM   #7
clancy_boy's Avatar
1966 17' Caravel
Kiln , Mississippi
Images: 8
Drum roll please..............
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 01:18 PM
Furnace Problem NOAZRK2690 Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-29-2011 02:25 PM
Red Max Pro Taxman Land Yacht/Legacy Motorhomes 6 09-28-2011 05:55 PM
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 3 07-04-2011 07:44 AM
Need advice on furnace. SilverRanger Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 03:47 PM
