Old 04-21-2019, 07:22 AM   #1
2015 28' Flying Cloud
Durango , Colorado
Furnace Failure
Happy Easter,
Our furnace fired up, then quit this am. Signal from thermostat controller seems to be reaching the furnace, I hear a solenoid click. Adequate gas at stove and water heater. Appreciate any troubleshooting suggestions. 47 deg in Hot Springs Arkansas last night.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 04-21-2019, 07:30 AM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Check for fault code light if equipped. Open outer furnace door and inner door. See control panel, a small light flashing? I think codes are on door.
Does it start a run cycle and then stops after a minute or so?
Details
GCinSC2 is offline   Reply With Quote
Old 04-21-2019, 01:25 PM   #3
Durango , Colorado
Details
No flashing light. Just a click upon signal from thermostat.
The last run cycle, this morning, did stop prematurely.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
Old 04-21-2019, 01:29 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
So you hear a click but the fan doesn't start? If so, sounds like blower motor or, if you are lucky, bad ground. Check all wires that terminate to the frame of the furnace. Remove screw/nut/spade connector, clean up, and re-install.
On some models the ON/OFF switch inside the furnace accessible from the outside is also a circuit breaker. Turn it off and back on again. Also, look for a fuse inside. On the models I looked at the thermostat sends 12V to the furnace which turns on the relay but if the CB is tripped nothing else happens.
Al
Old 04-25-2019, 06:59 AM   #5
Durango , Colorado
Al
Thanks, AI;
I had tried the reset switch inside the furnace. After removing and reconnecting all spades, it did fire off, but then quit after a few minutes. Did same again. I’ll have to get more deeply into this when we get home.
Thankfully, I carry a ‘Little Buddy’ propane heater for situations such as this.
Safe Travels,
JamuJoe
Safe Travels,
Joe & Joan Donnaway
Durango, CO
Old 04-25-2019, 11:22 AM   #6
"Cloudsplitter"
2003 25' Classic
Ck for a mud-dauber nest in the exhaust tube...AMHIK🥴
Old 04-25-2019, 12:20 PM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
We had furnace problem this year. Had a mobile RV service come. He pulled the furnace, cleaned the sticks and spider webs out, hooked the furnace up to his propane tank and 12 volts in his service truck and it ran fine. He put it back in the trailer and it did not run. He checked the gas pressure and flow. There was not enough gas flow for the furnace even though the stove and WH seemed to run fine. He checked the gas regulator and it was good. What he finally found was an internal collapse in a rubber gas line up at the front of the trailer. Changed that and put in a new regulator and the furnace has been running fine ever since.
Intermittent Gas Furnace Ignition Failure solar-guy Sprinter and B-van Forum 4 12-02-2016 08:42 AM
Furnace fumes from new furnace rosser7 LP Gas, Piping, Tanks & Regulators 15 06-01-2013 09:17 AM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
