Old 11-11-2015, 09:19 PM   #1
2009 25' FB International
York , South Carolina
Furnace control location
I will try this question here. In International forum I got no takers.
Recently purchased first time AS 2009 International 25. I am familiar with RVs in general as have had several SOBs. Here's my question. Where is the control to turn on gas furnace? I know it has a LP furnace as I've popped the cover on outside of trailer. Additionally there are multiple heat vents throughout trailer. In previous RVs the furnace control was always the wall thermostat. In this unit, heat setting at thermostat seems to turn on heat pump function in AC unit, ie. Only heat is coming from ceiling AC unit. Previous owner said he had larger AC unit installed at factory. Is it possible that in the upgrade, the furnace was disconnected since upgrade had heat pump? I pulled the thermostat to see if I could find any unconnected wiring because of a possible replacement thermostat but nothing but a phone type plug going into thermostat. This thermostat does have a "zone" feature but it doesn't appear to be functional? I would love to be able to use gas furnace. Any thoughts would be appreciated. What am I missing here?
bbodenstein is offline   Reply With Quote
Old 11-12-2015, 12:07 AM   #2
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
The thermostat should show a furnace option under mode but if it doesn't the first thing I'd have checked is the dip switches on the AC unit. We had to have the AC replaced on our 25' EB and the installer didn't properly set the switches and our furnace option was gone from the thermostat.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Power Gear "Control Box" Location? RAG Land Yacht/Legacy Motorhomes 10 09-16-2015 06:11 AM
Location of Control Unit for Fiamma Awning for 2014 Ext? Kwils25 Sprinter and B-van Forum 10 08-16-2014 09:55 AM
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 11:05 AM
location location location goransons Airstreams on eBay 0 12-05-2009 10:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 07:13 PM
