Old 11-19-2006, 07:37 PM   #1
2006 F350 V10 Ext. Cab LB
Driver1's Avatar
1998 30' Excella 1000
Sherwood , Oregon
Images: 12
Fuel Cell - Propane to 12V ??
Hi,
I've seen a 2001 article about a firm intending to develop a RV Fuel Cell system for converting propane to electricity for RV use. But, I'm having trouble finding anything further on the subject. Has anyone done it?
Best Regards,
Walt
Driver1 is offline   Reply With Quote
Old 11-19-2006, 07:53 PM   #2
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Is this it? (first hit on a Google for rv fuel cell)
Or this?
Also might try a search on the words fuel cell here.
Maurice
Old 11-19-2006, 07:54 PM   #3
Roscinante's Avatar
2006 19' Safari
Suisun City , California
"google it"
http://www.atwoodmobile.com/News/fuelcells.cfm
http://www.cleanfuelgeneration.com/components.htm
http://www.skyaid.org/rv/PropaneFuellCell2.html
Here are a few links that might get you started!
JERRY
Roscinante
Jerry and Avis
2006 Safari Bambi 19'
2005 Toyota Tacoma PU
"Mi Casa Es Su Casa!"
WBCCI #6716
AIR #17388
Roscinante is offline   Reply With Quote
Old 11-19-2006, 11:52 PM   #4
Driver1's Avatar
Sherwood , Oregon
Images: 12
Hi Maurice & Jerry,
Right, I'd seen the http://www.atwoodmobile.com/News/fuelcells.cfm and http://www.idatech.com/media/news.html?article=27 references but not the others. Do any of these mean there's a product on the market I could go out and buy today?
Thanks for your responses.
Best Regards,
Walt
Old 11-20-2006, 12:45 AM   #5
Pschoerrn's Avatar
1971 29' Ambassador
Braunschweig , Germany
Hi all!
These are already available in Europe, but run on Methanol not Propane... Prices between 1800,- and 3200,- Euro each!
Not cheap, a good solution!
Regards,
Björn
Björn H. Adam
Wolfenbuettel, Germany
AirstreamForumsMember No. AIR 5535
Proud Owner of a 1971 Ambassador 29' called "Dave"
-A stranger is a friend you just haven´t met before!-
unknown irish
davetheairstream
Pschoerrn is offline   Reply With Quote
Old 11-20-2006, 05:09 AM   #6
2001 34' Limited
The State of , Ohio
The direct methanol units are available in the U.S..
The $3,635 25 watt Efoy 600 unit, putting out about 2 amps, should give 40-something amp-hours per day, enough for the frugal boondocker. The $130 (with hazmat charge) twin 5 liter fuel cartridges should give somewhere between 2-3 weeks use.
Running a Fantastic Vent continuously or the furnace, we'd probably need one of the $5,000-something units that use twice as much methanol.
Maurice
Old 11-20-2006, 12:44 PM   #7
Driver1's Avatar
Sherwood , Oregon
Images: 12
Hi Maurice, Björn & Jerry,
The IdaTech news release did say, "IdaTech’s fuel cell systems include the company’s patented fuel processor technology to produce high purity hydrogen from conventional fuels, such as methanol, propane and diesel", but I've seen no fuel processor/fuel cell combinations available yet using propane. So we probably can't, at this time, get to a quiet, propane only energy source for our RV's. There is a nicety to stripping the hydrogen from the water in the methanol/water mix and hence the use of methanol vs. propane, but it really misses the advantage of a single fuel source and its storage.
Maybe there are furnaces, water heaters, refrigerators, and cooktops that will run on methanol.
Thanks for the leads and your thoughts.
Best Regards,
Walt
Old 12-09-2006, 10:51 AM   #8
Thermopiles are available now.
Thermoelectric devices are available now that run on propane, last 30 years without maintenance, have no moving parts, are very reliable, fairly small, and oh, so expensive.
I can not afford one, but it seems like an elegant solution to the problem of electric power in remote locations. Compared to fuel cell technology, though, they seem quite attractive.
Here's a link for more specific information. Global Thermoelectric - Home
My own solution is yet to be achieved, but I think I will build a permanent magnet DC alternator and run it using a bicycle. They are very efficient, produce power at low rpms, and won't wear out if the bearings are heavy duty, since otherwise there is no contact like with brushed generators. With modern niobium magnets they have reached the point of practical utility.
I have considered windmill, waterwheels, human power, solar panels, you name it. Of course, the easiest yet affordable solution is a gas powered generator, but I don't want to use more gas and have the noise.
Presently, I have two 60W solar panels atop my '58 Bubble, but they don't keep up with my power needs unless it is totally sunny and summertime with the sun up high. The array is not aimable yet, but the mounts I made can be upgraded for some additional angle adjustment. Even that won't give me the juice I want, and additional panels would have to be ground mounted since there's not much more roof on my little twinkie. I already have over $500 in the two 60-watters. By the way, I have not seen the official output claimed by the manufacturer, even at noon in June, so get more wattage than you think you'll need. Without direct sunlight, you get hardly any charge amps.
Hope this helps. Sorry for the long post, but I don't get out much.
Tom Hammer
"bubbleboy"
1958 Airstream bubble (I know, but it really is a '58, possibly the last one, SN493)
1953 Chevrolet 4-door sedan
1953 Dodge Power Wagon
1999 Volvo V70
Bubbleboy
bubbleboy is offline   Reply With Quote
12v
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
12V question uwe Electrical - Systems, Generators, Batteries & Solar 16 09-05-2002 01:14 PM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 01:15 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
fuel pressure PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 3 06-09-2002 08:40 PM
