Old 11-17-2005, 09:42 AM   #1
1975 31' Sovereign
Eau Claire , Wisconsin
Frozen Regulator?
A chilly greeting from western Wisconsin. We were hit with a typical autumn taste of winter storm a couple days ago that included driving rain followed by snow and plummeting temps. It was 4 above this AM. The propane tank that I was drawing off of ran empty and when I attepted to switch tanks at the regulator valve I found I could not do so because it was "frozen", I think.
My first inclination was to get out my torch and heat it up to free it. Fortunately, I saw the error of my thinking and I refrained. However, that still left me with the problem. Ultimate solution was tapping with a hammer to move it but this is not acceptable either and although it did the job in a pinch, I need to solve this problem before the next tank switch.
Is this regulator valve amenable to the use of a drying agent/lubricant as simple as WD 40? Am I correct that banging on it with a hammer to move it is asking for trouble?
Thanks in advance and also thanks again for all the previous excellent advice I have received.
Brouck
Wherever you go... there you are!
bhsl8 is offline   Reply With Quote
Old 11-17-2005, 09:55 AM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Do you think is it frozen from temperature? Or corrosion? Percussion adustments are always a last resort. Have you tried a heating pad?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 11-17-2005, 10:05 AM   #3
1975 31' Sovereign
I concurr with your assessment of concussion therapy, hence my quest for a feasable alternative. The last time I switched tanks, which had been required about every two weeks with the nightly temps in the 20-30s, it worked fine and has done so since I first aquired the coach.
Heating pad, hmmm... the thought of potentially loose electrons in the neighborhood of that propane gives me further pause. Also, if I have to change tanks more often now I don't want to do anything other than go out to the headend of the trailer and turn the valve.
I wonder if it might make sense to order a small ground tank from a local energy company. Anyone have any idea how small they come?
Brouck
Old 11-17-2005, 10:30 AM   #4
Rivetedude's Avatar
Yorktown , Virginia
Send a message via Yahoo to Rivetedude
How bout a hair dryer? That should be safe enough.
Ben
Go US Coast Guard!!!
"Keep You're Tin in the Wind"
My Photos
My MySpace!
Rivetedude is offline   Reply With Quote
Old 11-17-2005, 10:37 AM   #5
1975 31' Sovereign
A hairdrier just might work but that will be a real pain in the gluteus maximus to deal with in the middle of the night with a north wind howling down on me in my PJs.
No, I want to be able to just run out there and turn the valve.
Brouck
Old 11-17-2005, 10:40 AM   #6
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Or maybe Heat tape if this is a reocurring problem..........
I have seen at Home Depot, up to 100 Lb Propane bottles you can buy....
Good Luck
www.balrgn.com
Old 11-17-2005, 10:42 AM   #7
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
I'd still be careful with the hair dryer approach...electricity, heating element in hairdryer could be a potential hazard.
Can you disconnect the regulator, bring inside someplace to thaw and or clean?
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 11-17-2005, 10:50 AM   #8
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
How about the gel type heating pads that you can boil in the oven or microwave, and then use for medicinal purposes? You could heat one up, wrap it over the valve for a few minutes, and loosen the worst of the frost, anyways.
Another good option might be to make sure the regulator is dry during the day, and then cover it with a suitable hood type device, that does not allow the regulator to condensate and freeze. It will still get cold, of course, but if there's little or no moisture, then it can't freeze, right? Just remove the cover, switch over, and replace the cover.
But what do I know - living in SoCAl for over 20 years, frost is only on TV.
Uwe
www.area63productions.com
Old 11-17-2005, 11:02 AM   #9
1975 31' Sovereign
I definitely think I should cover the hardware to keep the moisture out and that might solve the problem in the long run. In the short run, does anyone think that WD 40 might help to make it easier to turn?
Brouck
Old 11-17-2005, 11:11 AM   #10
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
WD should help, or you can get a silicone spray, I use that more often now, seems to last longer. Is it the original regulator?
www.balrgn.com
Old 11-17-2005, 11:20 AM   #11
1975 31' Sovereign
Yes, well, I'm not sure. It has that "original" look, meaning old and contemporary for the 70s. It was on the trailer when I got it three years ago.
I think I will try the WD 40 first, since I have some on hand. I just don't want to do anything stupid.
Brouck
Old 11-17-2005, 11:25 AM   #12
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Well if it makes you feel better, I just removed a bunch of fittings and the refrigerator to my 73, including the isolation valves. They all were extreemly hard to operate. I used some WD to free them up then silicone as well, they operate fine. We pressure tested them (at work) and hold like new. Good luck and STAY Warm!
PS Fridge works on gas now I have it all back together!
www.balrgn.com
Old 11-17-2005, 11:35 AM   #13
1975 31' Sovereign
Excellent, then that is my plan. Thanks all, for your suggestions.
By the way, were the 100 lb propane bottles to which you refered, steel or aluminum and do you recall the price?
Brouck
Old 11-17-2005, 11:43 AM   #14
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
brouck
just call your local coop they will loan you the tanks and even hook it up for you.
can't remember who it is in stevens point, land of lakes coop perhaps...
john
you call them ferrets, i call them weasels.
LP Regulator PatCrusse LP Gas, Piping, Tanks & Regulators 27 05-15-2004 02:22 AM
Marshall 250 regulator failure nickcrowhurst LP Gas, Piping, Tanks & Regulators 11 04-18-2004 08:08 AM
Contents of holding tank frozen. Dave Emmerich Airstream Motorhome Forums 10 01-12-2003 08:31 PM
Grand Hall Ent. gas regulator recall 53flyingcloud LP Gas, Piping, Tanks & Regulators 0 12-23-2002 08:29 AM
Pressure Regulator pjtaia LP Gas, Piping, Tanks & Regulators 4 09-24-2002 08:26 PM
