Old 11-17-2005, 07:08 PM   #29
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Originally Posted by uwe
Would that not really make it freeze badly right afterwards?
Not only that but if water gets into it it could crack something. I think it might be better to just wrap a towel around it. it won't keep it from being cold but will limit the amount of moisture that reaches the reg and will still allow it to breathe.
By the way - that Fischer reg does not auto swap over. It is a manual operation. Even the new one I got from Inland which is a stock replacement does not swap over.
Another side note - back when I was serving my country in the NAVY, I worked on these types of regulators all the time. It is a sturdy regulator.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 11-18-2005, 09:18 AM   #30
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
That's odd.....
my old and new Fischer both switch over automatically (but you won't see the lever move).
I think the big tank is the best bet, but I love my auto changer.
Marc
Old 11-18-2005, 11:04 AM   #31
1975 31' Sovereign
Eau Claire , Wisconsin
Good Morning all,
When I went to have my tanks filled this AM the proprieter at the RV dealership where I now purchase my propane, informed me that there is no way to "repair" a regulator or lubricate it etc. He of course wanted to sell me a new regulator (which he did) but I am still not convinced that there are no other options.
It seems that the "switch to change tanks" is not a switch on the new one but an indicator for which tank the system is drawing from. When one tank empties, the regulator will switch automatically but through one's vigilance in watching for RED vs GREEN, the "switch " must be thrown so one knows which tank is supplying propane.
I have also found that I can rent a tank of 120 gallons (called a pig, Jeeze, I can harly wait...will it be pink?) for $75 per year and they will keep it filled for me. The price, because it will require more frequent filling, would be around $1.70 per gal... less than the #2.00 I now pay with all the hassle as well. Seems like a no brainer. That doesn't happen often, always seems like I live in the infamous "gray area".
Thanks again to all for excellent guidance and thoughtful suggestions.
Brouck
Wherever you go... there you are!
bhsl8 is offline   Reply With Quote
Old 11-18-2005, 03:57 PM   #32
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
Marc
Hmmm. I had better take a closer look at mine. I know on our trip to the playa for 2 weeks it didn't swap. I had to manually swap and relight everything...
maybe Andy can shed some light on this because I got it from Inland RV.
I assumed that the knob had to be swapped at that point.
Old 11-18-2005, 06:47 PM   #33
2003 25' Safari
Eden Prairie , Minnesota
Brouck - How long will you be Airstreaming in Eau Claire? In another few weeks it will be getting REALLY cold around here. At -20 I can't imagine that an Airstream will be very comfortable!
Dan
dmac is offline   Reply With Quote
Old 11-19-2005, 08:54 AM   #34
1975 31' Sovereign
Hey Dan,
Right now I am unsure as to how long I will be "holed up" in my trailer. It is possible that I may spend the entire winter in it. I forsee no serious problems unless there is a power outage and I freeze to death in my sleep. It will be an inconvenience yes, but also kind of an adventure. The furnance has so far worked flawlessly and I have been cozy.
I should have a better idea of how long I will be staying just before Christmas. I do dread the possibility of moving the coach now.
Brouck
Old 11-21-2005, 07:36 AM   #35
1975 31' Sovereign
Futher update
Mornin' all.
I put the new regulator on yesterday and so far all is well. It was an absolute battle getting the fittings off the old regulator since I lost most of my tools in the "war" aka Brouck's divorce. It was indeed the original regulator having been inspected in Jan of 1974.
Still plan to switch to the 125 gal pig.
Also, finally put the antifreeze in yesterday so I think I can make it through the winter now. Was above freezing over the weekend so most of the first snow is gone.
Brouck
Old 11-21-2005, 09:00 AM   #36
1975 Argosy 26
1963 24' Tradewind
Buttercup...
Just as a FYI, I did not buy my Fischer from Inland, I got mine from a local Propane distributer. It looked a bit different from Inlands, but the specs are the same (and autochange overs).
Marc
LP Regulator PatCrusse LP Gas, Piping, Tanks & Regulators 27 05-15-2004 01:22 AM
Marshall 250 regulator failure nickcrowhurst LP Gas, Piping, Tanks & Regulators 11 04-18-2004 07:08 AM
Contents of holding tank frozen. Dave Emmerich Airstream Motorhome Forums 10 01-12-2003 07:31 PM
Grand Hall Ent. gas regulator recall 53flyingcloud LP Gas, Piping, Tanks & Regulators 0 12-23-2002 07:29 AM
Pressure Regulator pjtaia LP Gas, Piping, Tanks & Regulators 4 09-24-2002 07:26 PM
