Old 11-17-2005, 11:00 AM   #15
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Originally Posted by bhsl8
Excellent, then that is my plan. Thanks all, for your suggestions.
By the way, were the 100 lb propane bottles to which you refered, steel or aluminum and do you recall the price?
Steel, painted white, but John has a good point, a local propane dealer would most likely set you up! (for a fee)
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 11-17-2005, 11:01 AM   #16
1975 31' Sovereign
Eau Claire , Wisconsin
Hey John, that makes a lot of sense and I will explore it tomorrow. I like the idea of them doing the work.
Good luck hunting. Where do you go? I gave it up after the last time I went out I saw so much orange, I thought I was at a Denver Broncos football game.
Brouck
Wherever you go... there you are!
bhsl8 is offline   Reply With Quote
Old 11-17-2005, 11:08 AM   #17
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
If you do choose to lubricate, do not use a petroleum based lubricant because it may deteriorate the rubber in the regulator. Silicone should be no problem.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 11-17-2005, 12:27 PM   #18
1975 31' Sovereign
That would rule out WD 40 then , would it not? Thanks for the tip.
Brouck
Old 11-17-2005, 12:59 PM   #19
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
elroy/new lisbon area... not too many hunters up that way yet...
why don't you wait and have the propane guy look at your regulator when they are there.
rickstream got his brand new fisher regulator for about 60 bucks from the coop. (yes the exact one that everyone else says is no longer available and charge 200 bucks for!!!)
let a pro handle it.
john
you call them ferrets, i call them weasels.
Old 11-17-2005, 01:00 PM   #20
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Automatic switchover....
don't the orginal Fischer valves come with an automatic switchover? I.E. - one tank empties, and the other comes online? My new Fischer does this, and gives me an empty flag on the tank that emptied (that the selector is pointing too).
That should save you the trips in the night too.
Marc
Old 11-17-2005, 01:01 PM   #21
1975 31' Sovereign
Well put John, I will post results of the quest.
Brouck
Old 11-17-2005, 01:46 PM   #22
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
I believe it would.
Old 11-17-2005, 02:34 PM   #23
1975 31' Sovereign
Hey Marc,
That has not been the case with mine as I've had to switch every time one tank is empty. Perhaps it is faulty. At any rate, it would not have swithced over last night. It was just plain stuck. Another problem arises for me with present setup if I should run out of gas just after leaving in the AM or I should be out of town. Then I have to restart the furnace etc. All in all a damn nusiance.
Brouck
Old 11-17-2005, 04:48 PM   #24
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
New!
I'd be all over a new automatic switchover regulator by now. They're not that much money, considering the convenience and safety they offer.
Uwe
www.area63productions.com
Old 11-17-2005, 04:55 PM   #25
Images: 8
120 gal. tank
Just to second the suggestion of having a tank delivered... the company I used out here was Amerigas, they dropped off a 120 gal tank for about $70, will take it away for free if I want to move. It is white painted steel. I didn't want the hassle of filling up a tank every 2 weeks either, and without the discount of buying in bulk. I still have a half full tank on the tongue.
Kinder is offline   Reply With Quote
Old 11-17-2005, 05:29 PM   #26
amron's Avatar
1953 25' Cruiser
Sterling , Virginia
Images: 13
pending fixing it, pour some hot water on it.
amron is offline   Reply With Quote
Old 11-17-2005, 06:30 PM   #27
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Would that not really make it freeze badly right afterwards?
Uwe
Old 11-17-2005, 06:51 PM   #28
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I guess if you had fast fingers, you could switch it over before it refroze. Although if you think about it, you are changing the switch because you are out of propane, and if you are, there will be nothing to heat the water...
LP Regulator PatCrusse LP Gas, Piping, Tanks & Regulators 27 05-15-2004 01:22 AM
Marshall 250 regulator failure nickcrowhurst LP Gas, Piping, Tanks & Regulators 11 04-18-2004 07:08 AM
Contents of holding tank frozen. Dave Emmerich Airstream Motorhome Forums 10 01-12-2003 07:31 PM
Grand Hall Ent. gas regulator recall 53flyingcloud LP Gas, Piping, Tanks & Regulators 0 12-23-2002 07:29 AM
Pressure Regulator pjtaia LP Gas, Piping, Tanks & Regulators 4 09-24-2002 07:26 PM
