Old 11-11-2008, 07:42 AM   #1
1970 25' Tradewind
Glen Burnie , Maryland
Forklift Tanks
I have access to several used aluminum 33 1/2 lbs LP tanks that were used to fuel forklifts. I know I can have them rebuilt and inspected if necessary, but as long as they have the OPD coupling, shouldn't they be a straight replacement for the twenty pounders I have now??
Zoomie is offline   Reply With Quote
Old 11-11-2008, 07:48 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Forklift tanks are generally used horizontally, rather than vertically. You may run into a problem with picking up liquid, rather than vapor, and the collar on a forklift tank is very different than a standard LP tank. You may have a problem securing the tank to your trailer.
Old 11-11-2008, 08:58 AM   #3
1975 29' Ambassador
Reno , Nevada
If you can get an OPD valve on one of the ports you should be a go. Getting the right OPD valve might be a problem as even an OPD for the standard 30# aluminum RV tanks often confused people.
The collar is an issue in that it goes completely around. The hassle as I see it is going to be hose access to the OPD valve. (see foreground in pic at propane101)
I am a bit confused by Terry's observation. The forklift tanks I saw at a local propane dealer are for vertical mount (DoT). They have multiple ports on top inside the collar. Horizontal tanks (ASME) usually have the ports on the side like in my B-Van or serving mobile homes. I would think a horizontal forklift tank would be and permanently installed.
In another thread on this, Lewster indicated that forklift tanks did not have an 'RV rating' but I have yet to find any other mention or description of this rating.
Old 11-11-2008, 09:24 AM   #4
Well Preserved
1993 21' Sovereign
Here is a horizontal LP tank on a forklift, it is designed to be removed and refilled. Most forklifts travel too slowly to drive them to the LP filling station:
ID:	71230   Click image for larger version
Old 11-11-2008, 11:25 AM   #5
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Some forklift tanks have vapor and liquid ports. BUT they only work properly if mounted correctly. Most are horizontal mounted. You may want to get a floor buffer tank if you need a vertical tank.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 11-11-2008, 12:05 PM   #6
1975 29' Ambassador
Reno , Nevada
Thanks for the pic, Terry. The tanks I saw, like those in the pic I referenced, look just like standard RV tanks except the collar was a complete circle rather than the 3/4 on typical RV tanks and much smaller than the overall tank diameter. They also had the typical RV stand ring on the bottom. The propane dealer had nearly a hundred of them standing around his filling station. It may be we are getting our equipment crossed like sometimes happens with industrial batteries vs rv batteries - in this case forklift versus floor buffers.
I think the new OPD valve would be the critical easy to identify feature as that is only used for vapor feeds (at least as far as I know). It should also be fairly easy to determine if the tank is designed for horizontal or vertical mounting by the brackets on the tank.
It does underline the need to be sure you get a properly certified tank designed for mounting and use in the way you need it with the proper feeds for your intended service.
Old 11-12-2008, 03:24 PM   #7
1972 Travelux Princess 25
Cobourg , Ontario
Wouldn't the propane dealer know if they will work? Or if he doesn't, could he find out from the tank manufacturer?
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 11-12-2008, 03:56 PM   #8
Horizontal fork lift aluminum LPG tanks, "WILL NOT" work vertically.
Same way vertical tanks will not work horizontally.
I doubt that a LPG refill station would know the difference.
Old 11-12-2008, 04:19 PM   #9
1970 25' Tradewind
Thanks all. I'll check before I invest.
Old 11-12-2008, 04:47 PM   #10
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
Andy is right. You would think a company that only sells ONE product, would know all about that product. Propane distributors are one of the most ill informed and fickle lot I have ever run into.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 11-12-2008, 08:04 PM   #11
GO Bob's Avatar
1982 34' Limited
1975 31' Sovereign
Grovetown , Georgia
The horizontal tank has a L pick up. That is why they have a label "this side up". So when on its side it will draw vapor and vertical it will still be in vapor. Most of horizontals had an "OPD". If the horizontal could not work vertically they would have to be stored horizontally. The problem comes from the collar and some non standard (to RVs) connections. This comes from a HAZMAT class. We were shown what a 20lb. will do left on its side in the heat of summer.
"Humans get a lot done,not because we're smart, but because we have thumbs so we can make coffee." Flash Rosenburg
"Decaffinated coffee is the devil's blend."
GO Bob is offline   Reply With Quote
alum. forklift propane tank for airstream doityourself Exterior Storage Compartments & Access Doors 8 04-18-2009 10:15 AM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 08:34 AM
Tanks out. Now What? Safari Tim Waste Systems, Tanks & Totes 34 08-05-2006 10:37 AM
Where to get new tanks? JimGolden Waste Systems, Tanks & Totes 7 03-15-2006 07:52 PM
Forklift tanks??? Kestrell LP Gas, Piping, Tanks & Regulators 10 10-23-2005 09:02 AM
