Old 10-21-2005, 09:01 PM   #1
Kestrell's Avatar
2005 28' International CCD
Upland , California
Forklift tanks???
Does anyone know of any problems with using aluminum propane tanks off a forklift to replace the house tanks on a Stream' ?
Kestrell is offline   Reply With Quote
Old 10-22-2005, 03:52 AM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
I don't think you wnat to do that, Fork lifts run on Liquid Propane...
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 10-22-2005, 04:15 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Forklift tanks deliver propane as a liquid to the forklift engine. RV tanks deliver propane to the stove and heater as a gas. They also are mounted differently. You may be able to modify them, but I would think it would be cheaper to just get new tanks.
Richard
Old 10-22-2005, 05:33 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Some Forklift tanks have the vapor ports on them too...But they are not designed for RV use, they won't fit the racks properly, you would have to adapt the fittings to your AS...etc, etc. Why did you want to use forlift tanks? The ones I have seen cost more than the regular tanks
Aaron
WBCCI #XXXX AIR #2495
Old 10-22-2005, 06:12 AM   #5
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
They do look like beer kegs and some have nifty guages. But, most are designed to be used horizontally, so if they are vertical, the ports will not work correctly. You may have liquid coming out of a vapor port if a horizontal tank is used vertical and vice versa.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 10-22-2005, 07:25 AM   #6
till's Avatar
Lisle , Illinois
Images: 108
I started down this road myself. Forklift tanks can be had cheep if you know the right people. But as stated above, the conversion process to make the tanks work is not easy and you will have problems with the over fill valves too. Also, some shops will not want to touch them when refill time comes since they are non-standard. Pick does have a good point on the cool factor though....
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 10-22-2005, 07:53 AM   #7
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Uh... guys... my tanks are mounted horizontally... hmmm...
Roger
Name:	propane setup.jpg
Old 10-22-2005, 08:43 AM   #8
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Roger
Yes but your not using LPG (I hope)
www.balrgn.com
Old 10-22-2005, 09:04 AM   #9
85MH325's Avatar
Tipton , Iowa
Images: 37
Yep. From the factory. Horizontally mounted Worthington aluminum propane tanks. That's what's under the cone-shaped fiberglass hood on the tongue. Two of 'em. 40 pounders with straight valves. OPD not required. There's several threads here about them. I don't see why a horizontal forklift tank wouldn't work on an Airstream, as long as the fittings would work. The only way I can get them filled at anyplace that's not a pro-LP place is by explaining that they're no different than forklift tanks... and most of those places have filled forklift tanks at one time or another. As a matter of fact, Airstream and other MoHos use horizontally mounted LP tanks as well, and they fill them without comment. It's just that these are removeable that give's 'em fits.
Roger
Old 10-22-2005, 03:03 PM   #10
Depends on the regulator. Many of them do not want to see liquid propane. Hopefully, Nick Crowhurst will catch this thread as he he has commented in the past about a particular issue with regs seeing LPG instead of gaseous.
joatmon is offline   Reply With Quote
Old 10-23-2005, 09:02 AM   #11
Kestrell's Avatar
Upland , California
The forklift tank idea was attractive because I spotted a couple of nice sized aluminum ones on E-bay for $50.
Another reason for aluminum tanks rochleau Our Community 4 09-03-2002 06:30 PM
LP Tanks Craig LP Gas, Piping, Tanks & Regulators 6 08-22-2002 08:43 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
