Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 06-28-2009, 01:41 PM   #1
Profile:  1974 Argosy 24
Winston Salem , North Carolina
flexible LP line ????
Another adventure in refurbishing my Argosy
after testing the waterlines i found out that the system is leaking like a, well you know what.
leakes in the water lines will be easy to fix for me.
The water heater is corroded through, i found out about it after taking the heater out and inspecting the tank, pinholes everywhere
so, new heater is ordered -Atwood G6A-7-.
Here is my question
i had to cut off the gas supply line from the old heater since it would mot move and damaged it a bit
so i will need to replace the line from the nearest connection which is just about 12-15 inches from the heater.
could i replace this with a flexible hose, if so where would i find one that is approved?
or do i have to replace it with copper tubing and get a flaring tool and benders?
i have included a picture of the area in question
michael13 is offline   Reply With Quote
Old 06-28-2009, 01:53 PM   #2
Profile:  1977 27' Overlander
1963 19' Globetrotter
naples , Florida
I see no reason why you couldn`t use a flexible line,just make sure you sleeve it where it goes thru the belly pan and floor.You should be able to find a flex at a plumbing supply house,or maybe Home Depot. Dave
easyride is offline   Reply With Quote
Old 06-28-2009, 02:35 PM   #3
FT RVing
lebolewis's Avatar
Profile:  1976 31' Sovereign
A place w/low Humidity , FT RVing, north & south
Flexible propane hose
I recently replaced my old Bowen water heater with an Atwood heater. The entrance to the new Atwood heater for the Propane supply was in a different location than for the old heater, making it necessary to drill a new hole in the floor and provide a new propane hose. I looked everywhere locally for a flexible Propane hose with the proper connections or that could be adapted.....but no luck. I even paid a visit to the local wholesale house that is used by gas and propane installers.....but no luck. Finally, I just used soft copper tubing and made flange connections on both ends. I had access to a flange tool and a pipe cutter....but no bender. I just did the bending by hand. Not as neat as I wanted, but it works.
After it was all done, I found what I needed on the Internet at this site.
Propane Accessories and fittings
When you get a chance to "Dance" or "sit this one out".......I hope you DANCE!
lebolewis is offline   Reply With Quote
Old 06-28-2009, 02:58 PM   #4
Jim Foster
Jim Foster's Avatar
Profile:  1965 17' Caravel
1983 27' Excella
Walnut Grove , California
Many RV parts outfits carry flex rubber hose in various lengths used to connect your propane regulator to the main supply line to the trailer. Most will have any number of adaptors for the ends.
I would use that type of hose as it will withstand vibration as well as weather if part of it is outside the coach.
Old 06-28-2009, 04:33 PM   #5
Liberator
klattu's Avatar
Profile:  Heart of Dixie , Alabama
Images: 841
As Jim says...
Vibration makes me want flex for all lines
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator
klattu is offline   Reply With Quote
Old 09-23-2009, 01:54 PM   #6
Profile:  1971 31' Sovereign
Ocala , Florida
Does anyone know of a place to get flexible (rubber) hose for propane lines in a 30 foot length?
cjohannesen is offline   Reply With Quote
Old 09-23-2009, 02:18 PM   #7
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
We have a local LP station that we get our tanks filled at that will make up any length of hose you want. You may want to check around to see if there is one by you too.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 09-23-2009, 04:49 PM   #8
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
We used a 3/8 x 36' flex line from Lowe's -the yellow plastic coated stainless type. Painted the part on the outside silver and used rubber grommets where it passed through the belly and the tank housing. There was enough flex that we didn't have to drill a new hole in the floor. The excess I just curled up inside the tank housing.
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 09-23-2009, 06:16 PM   #9
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
I am surprised that no one has mentioned anything like a CODE. Rubber hose carrying gas inside is not a good idea. If it was don't you think the expense minded "bean counters" that control manufacturing would have adopted the use.
The yellow colored gas piping is very easy to work with and flaring is easy so do it right.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 11-04-2009, 10:18 PM   #10
Profile:  1958 22' Flying Cloud
Sacramento , California
that makes sense
kaisermd is offline   Reply With Quote
Old 11-08-2009, 07:57 PM   #11
naples , Florida
Rubber gas hoses
I just connected all appliance in a restaurant,they all came with rubber flex connectors ,and quick disconnects.They did conform to code.
Dave- Master Plumber State Certified
Old 11-08-2009, 08:54 PM   #12
Alwhisman's Avatar
Profile:  1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 57
Send a message via Yahoo to Alwhisman
This is what Gary was most likely talking about. You have to use the fittings for the product to be safe.
Gas Piping, Dia 0.745 In, Training Guide - Flexible Gas Hose Accessories - HVACR Controls - HVACR : Grainger Industrial Supply
Al
Alwhisman is offline   Reply With Quote
Old 11-10-2009, 12:40 PM   #13
Profile:  BullHead City , Arizona
Had all our lpg lines made at House of Hose.It makes all kinds of hoses hydraulic, fire and any kind you want. They were made out of rubber. This is a local Las Vegas shop. but there might be something similar in your area.
Gypsy Jo 1977 Argosy 28' Motor Home
Gypsy Jo is offline   Reply With Quote
Flexible moldings Maryw164 General Interior Topics 0 04-26-2009 04:49 PM
Flexible tubing replacement Tahoe Joe LP Gas, Piping, Tanks & Regulators 7 09-16-2006 10:28 PM
Flexible Heater Tube Hawk_Man Water Heaters, Filters & Pumps 1 04-19-2006 03:07 PM
HD flexible hose OK? TomW Fresh Water Systems 8 10-17-2004 12:50 PM
