Old 04-02-2008, 09:33 PM   #1
Moscow , Idaho
Flame King Auto Switchover Regulator
Someone stole my automatic switchover regulator and hoses. Scum Bags!!
Anyway in my search for a replacement I ran across the Flame King brand automatic switchover regulator with the hoses attached. What I really liked about their setup is they use the new style (OPD) connections. No tools needed to change the tanks. YEAH!!!
Has anyone heard anything good, bad or what ever regarding this regulator setup?
Complete setup with hoses, cover and mounting screws less than $49 delivered to my door via Priority Mail.
Cissell is offline   Reply With Quote
Old 04-02-2008, 10:29 PM   #2
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
Hoses look to short for a squarestream
Jimmini :
AKA : TUMBLEWEED. Just an old buzzard with a itch to yonder.
Cowboys have a way of looking at things a little differently than most folks.Their wisdom is simple and more down to earth.
jimmini is offline   Reply With Quote
Old 04-03-2008, 04:46 AM   #3
Dan@LED4RV's Avatar
Denton , North Carolina
Gas change over
I can't comment on the dependability of the Flame King as we have never carried their products. It may work just fine. I think Flame King as been making grills for some time and doing a pretty good job.
This is the one we carry and have had very little if any problems with - Auto Change-over Gas Regulator.
We will send the self tapping screws that attach the regulator to the bracket. If you use screws that are not the right size and strip the holes that hold the regulator to the braket, it can be a real hassel.
We do have the hoses that WILL fit on this automatic switchover regulator and does not need any thread seal tape or dope. It is the flaired brass self-sealing type. The length will be more than adequate to interface from the regulator and the gas bottles. See Gas Hose w/Flair End.
There is no comparison between the "old brass and wrench" vs the "new hand tighten style". The new "new hand tighten style" is so much nicer that is is well worth the extra money you have to spend if you have to change/replace your automatic switchover regulator or change your valves.
If you go to states that require the new style OPD (Overfill Protection Device) and have Aluminum tanks you most likely will want to change your valves. I have heard of people going on outings and refused gas because they did not have the right valves. Buying new gas tanks on your outing can be expensive. See 30 lb OPD Valve for Aluminum bottles.
There is a differance between regular steel tank OPD valves and the
Aluminum OPD valves. The steel tank valves will not work in the Aluminum bottles.
The companies that do pressure checks on gas bottles have the tool to put the new valves into the bottles. More than likely, they do not have the valves that go into the Aluminum tanks.
New tanks have to be inspected every 12 years and old tanks with new OPD valves have to be inspected every 5 years. If you have steel tanks it is best buy them locally, but if you have Aluminum tanks it is worth the extra effort to get the new valves.
Dan@LED4RV is offline   Reply With Quote
Old 04-21-2008, 07:20 AM   #4
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
Does anyone know if these can be repaired or do they just get replaced when they conk out. The one that was installed at the factory as apparently assumed room temperature. When the switch is pointed at one tank and the other one is removed for re-filling, there is propane escaping from the hose without the tank while the other is in use - that shouldn't happen.
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
flame indicator DavidsonOverlander Refrigerators 2 08-14-2007 10:36 AM
King tut Boondocker Off Topic Forum 7 08-08-2006 04:50 PM
Flame Decals?? prosend Clearcoat, Exterior Paint & Trim 6 02-11-2006 04:51 PM
Testing regulator auto switch over Safari Tim LP Gas, Piping, Tanks & Regulators 2 08-01-2004 11:39 PM
LP tank switchover Silvertwinkie LP Gas, Piping, Tanks & Regulators 6 03-12-2003 05:20 PM
