Boxfotos, if something is frozen it likely is the valve itself. Run the furnace, redirect your heat lamp to the valve area, be patient, don't pull hard on the valve handle. The furnace must be run to protect anything under the foor, including the tanks.
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
