2012 Interstate Coach
From All Over
, More Than Anywhere Else
Originally Posted by BradMarkB
Unable to get propane flow from exterior LPG Port to grill, with all hoses attached, tanks full, could there be an air block?
Does your grill have a regulator? If so, that's your problem. The flow from an exterior LPG port is already regulated, so having another regulator at the grill chokes down the flow to almost nothing.
My guess is there is a maintenance shutoff valve that is used to protect against leaks for users that don't use the option. But it is only a guess (appliances are meant to have a shutoff valve where they connect to the supply).
