01-26-2018, 04:40 PM
1971 27' Overlander
Findlay
, Ohio
Exterior gas lines on belly
I apologize because I know nothing about this in advance, but my AS have the LP lines hanging under the belly. Is this the AS norm or should they be internal? I want to remove the pan to see the water tank and most likely replace it but this requires removing the gas lines, no? Any help is appreciated. Thanks!
01-26-2018, 04:53 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
It is normal to have the propane plumbing outside the belly pan under the trailer. If one of the lines springs a leak, the propane escapes into the air. If the lines were inside the belly pan, a leak could fill the belly pan with propane. Which would be dangerous in a "BOOM!" kind of way.
01-26-2018, 05:19 PM
Schoharie
, Unknown
I believe it is the norm(safety) as gas build-up between the sub-floor and belly pan would be disastrous. L.P. is heavier than air and would stay trapped if enclosed... I replaced all of the rubber hoses and tank regulator and from what I saw, it wouldn't be too difficult to take the hardlines down. You might be able to get away with moving the line out off the way of your tanks after disconnecting your rubber tank supply hose and the hangers... Good luck...
01-27-2018, 06:13 PM
1974 27' Overlander
Baltimore
, Maryland
External leak = cold gas. Internal leak = potential explosion. External is safer, and the way it's supposed to be installed.
07-14-2018, 02:08 PM
2018 25' Flying Cloud
Springfield
, Vermont
Protecting the external copper propane lines
Has anyone felt apprehensive about the exposed copper propane lines?
I added some foam insulation but not sure if I’m just being paranoid.
07-14-2018, 02:15 PM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
What good would the insulation do?
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
07-14-2018, 03:36 PM
1994 34' Excella
Warren
, Manitoba
The foam "insulation" is used as a protection for sharp rocks being thrown by the tires against the gas lines. Some people use old garden hose, which is cut like the insulation, and lasts a lot longer. I have used both over the years. If you have to travel a lot of gravel roads it is a good idea to protect the lines. JMHO
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
07-15-2018, 04:28 AM
Springfield
, Vermont
Didn’t think about garden hose! That would work well.
We’re heading west this week so will see how it holds up.
07-15-2018, 05:24 AM
2017 25' International
Niagara-on-the-Lake
, ON Canada
New units from the factory use Pex tubing around the copper propane lines.
Ray B.
07-15-2018, 06:40 AM
2014 27' Flying Cloud
Viera
Before we went to Alaska in 2012, I encased all my gas lines in old garden hose held in place with UV resistant zip ties. I’m not sure it was worth the trouble. Others on the trip didn’t do it, some who had been many times never did it, nobody had any trouble with damaged lines.
Randy & Pat Godfrey
Florida Airstream Club (027)
ACI# 1212 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
The best part of any trip is when you pull away from home.
07-15-2018, 08:26 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The biggest issue with copper is a rock that collapses the tube. Yes, that's a pretty big rock. The collapse is normally how you get a break / leak. If you are going to "protect" it, you need a covering that is stronger / more rigid than the copper. The various forms of plastic stuff they put around wiring is not going to help much in this case.
07-15-2018, 08:41 AM
2019 27' International
2014 25' International
Boulder City
, Nevada
I did what jrenard Post #5 did. After a couple years the stones pretty well took care of much of the foam insulation. We do a lot of traveling on gravel roads, in comparison to those who do not.
Water is also absorbed into the foam. If traveling on salted roads for winter or along the coasts, salt is corrosive and will 'digest' copper. It remains in the foam after it dries out.
Plastic is best, but installed so water does not enter from the open ends.
What have I done lately with this issue... nothing, but like jrenard... something is better than nothing. Nice job! Mine did not look as professional.
The current trailer I took some gutter galvanized metal that is bent at a right angle, duct taped one end to the bottom of the trailer. Stones will pummel the metal with no ill effects to the copper that is at a right angle to the direction of travel. Does not look professional, but I do not want to use screws into the aluminum skin, either. I could cement the metal to the aluminum skin, but then replacing it would be an additional project.
It need not look pretty, just does the job.
The copper lines that run in the direction of travel, have little exposure to stones.
Protagonist has the best reason. Airstream should be doing more about these exposed copper lines as we all recognize this as a problem... years ago.
Human Bean
07-15-2018, 09:20 AM
Springfield
, Vermont
I agree... and good point about absorption. We are in New England and salted roads are above and beyond comprehension. Will plan on seeing how this trip plays out (about 4,500 miles).
Now some deflector shields for the drain valves...
