10-13-2006, 07:06 PM
2012 28' International
New Orleans
, Louisiana
Entrance Door Covers Heater Exhaust
I just lit off the furnace in our new Safari we purchased in May. I want to burn the furnace in to get the new furnace odor out of the camper and this is the first night it has even been cool enough to do it. I have all the windows open and I had the door open then realized that the door covers the exhaust from the furnace when it is open. I caught the problem before it got hot enough to damage the finish but is sure is a poor design. Just a heads up to everyone to watch out for a potential problem. I assume AS didn't think anyone would run the furnance and leave the door open.
Thanks Jim
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
10-13-2006, 07:26 PM
_
hi jim
there are several models with the furnace curbside and the door at risk....
it really is an issue....
short of not having the furnace there the options i can think of are...
1. a protective plate/surface on the door
2. an auto shut off switch that kills the furnace IF the door is fully opened..
unless you work out some reminder system,
it is a bit like the tv antenna, not if you'll ever leave it up..but when.
cheers
2air'
10-13-2006, 08:02 PM
New Orleans
, Louisiana
Originally Posted by 2airishuman
hi jim
cheers
2air'
I will figure something out. If it were really cold the door would be closed. I might look at a lockout sysem that would let the door to be used for normal use and only lockout when the door is open all the way. I would also think the back pressure on the exhaust would be a fire hazard.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
10-13-2006, 09:32 PM
Salem
Thanks Jim
Hi, I accidentally done that myself, But I told myself that common sense is that you don't have your door all the way open with the heater on. I since then made sure that the door never gets opened farther than 90 degrees or straight out from the side of my trailer when the heater is on.
Hi, 2air. I do like your idea of some sort of safety switch to, lets say, shut the heater off when the door is opened. A door jamb switch wired in line with the heaters thermostat would work.
10-13-2006, 09:35 PM
1965 17' Caravel
1968 28' Ambassador
Butte
, Montana
Hi, 2air. I do like your idea of some sort of safety switch to, lets say, shut the heater off when the door is opened. A door jamb switch in line with the heaters thermostat would work.
Great Idea !
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
10-14-2006, 08:40 AM
Furnaces have a heat-sensing limit switch mounted on the firebox that prevents the fan from stopping until the box is cooled sufficiently. Even with a "door switch" the fan will still run and expell heat from the vent until the limit switch says it's OK for the fan to stop. Opening the door to go in and out of the trailer while the furnace is running is not a problem since it most likely is only partially opened. Leaving the door wide open and running the furnace is not something logical people would do. If you must "burn-in" your furnace, open the windows and turn the AC on - may as well break that in, too, and save some time. Darol
10-14-2006, 09:22 AM
1994 30' Excella
Mississauga
I almost left the door open once and since my trailer is painted it would have made a real mess of the finish. When I was looking at trailers a few years ago an owner showed me the discolouration on his door. He had run the furnace while working on his unit to take off the chill. I guess he saw red when he realized his mistake.
Why not install a strap to the top of the frame and door to only allow the door to open 90 degrees when running the furnace. Put a hook on one end so that it can be disconnected when you want the door open all the way.
Al
10-14-2006, 11:00 AM
2000 31' Land Yacht
Originally Posted by Darol Ingalls
Leaving the door wide open and running the furnace is not something logical people would do. Darol
I object to your statement above. We have slip-in plastic panels in the screen door that allow us to have the main door open for light and welcoming look. We often run heat or A/C with the door open. Having the exaust directed at the open door is DUMB, like many things A/S does, apparently because nobody there actually uses the product.
10-14-2006, 04:41 PM
New Orleans
, Louisiana
Spock
Dam, after 57 years I have been diagnosed as illogical. Thank you Spock, I mean Darol.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
10-14-2006, 08:25 PM
Salem
Hi, Jim. Don't worry, I think they have a cure for that!
10-14-2006, 09:18 PM
1969 31' Sovereign
Broken Arrow
, Oklahoma
IMO there is nothing logical about it. I think a bungie cord on the door to prevent the door from staying wide open when using the furnance would be a good idea.
Garry
10-14-2006, 09:36 PM
2007 23' International CCD
Lapeer
, Michigan
We would forget on occassions when we were going in and out repeatedly as when setting up the fire or food on the outside table, in and out with the dogs or for pictures or running to see something, carrying things in from the truck, etc., or worse when the heater was not on but then went on when it was cooler. We leave our door open alot and never really thought of the heat being on or not until we smelled something funny or went to close it and thought of it then. Luckily no damage but always a fright of it and relief. It would have to be nearly storm conditions for us to be concerned with the door being open when we and the 2 dogs are active about the trailer in and out. We must have all been born in barns and not just the dogs. But the furnace still warms the AS regardless. In cooler weather camping it's nice for all of us not to have to open and close the door every time we go in and out. With the new AS we do not have that worry. I don't know if it's so much illogical as it is not energy conservative.
10-15-2006, 02:40 AM
2007 25' International CCD
Arlington
Al
An excellent "low tech" solution!
10-15-2006, 05:39 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
I think the bungie cord/strap solution is the best low tech answer I have seen. FWIW both my 75 and my 80 have the furnace vent behind the door. The main problem with moving the furnace is you would lose valuable cabinet space somewhere else. When you pack as much livability into a 150-250sf tube as Airstream does, you are going to have to make some compromises.
Aaron
WBCCI #XXXX AIR #2495
