Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 07-18-2017, 12:12 PM   #1
Wichita , Kansas
Empty tank?
Could someone explain how the dual tank and regulator works please? Completed the remodel on our 74 Safari and using lp for hot water. I only turn on one tank with arrow point at and working fine. Sight glass very fogged but do see some red. Do I re direct the arrow to the other tank and disconnect the empty one and refill? Then do the same process, assuming the sight glass turns green? Thanks ahead.
nhisservice is offline   Reply With Quote
Old 07-18-2017, 12:41 PM   #2
Reads a lot
Titusville , Florida
Yup, seem like you have it right. I don't run out and fill the lp tank that day but I would refill the empty tank as soon as possible the when tank 2 reads empty reverse the procedure.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 07-18-2017, 04:23 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
The way it is supposed to work is that you turn on the cylinder valves on both cylinders, and point the arrow at the emptier of the two cylinders. The reg draws gas from that cylinder, mostly, until it gets empty, then starts drawing gas from the other one and throws the red flag.
The red flag won't be clearly visible unless you're actually using propane, so if you check it before a trip, light a burner on the stove or turn on the water heater or something so you get an accurate indication.
Typically you leave the arrow pointing at the empty cylinder until you replace it, because that way you won't get any gas flow from the pigtail when you disconnect it. Modern pigtails have backchecks so it doesn't matter as much any more.
Old 07-19-2017, 09:03 AM   #4
Wichita , Kansas
Thanks a bunch. I've been running on one tank most the summer but only using it for hot water a few times. Good to know the gauge is only accurate during use too.
Knowing when propane tank is full or empty Judypetrick LP Gas, Piping, Tanks & Regulators 31 06-10-2015 09:40 AM
Basic h/w heater question (empty tank) TennisMan Water Heaters, Filters & Pumps 4 03-01-2011 02:19 PM
How do you empty septic holding tank? Macymac Member Introductions 5 03-24-2010 05:15 PM
HELP - Need to empty LP tank for export ViewRVs LP Gas, Piping, Tanks & Regulators 7 03-16-2010 07:23 PM
Black Water Tank Shows Full When Empty yochanan Waste Systems, Tanks & Totes 12 01-21-2006 10:41 PM
