Join Airstream Forums Today
Old 11-01-2011, 07:00 PM   #15
BEWARE of the CAT
w7ts's Avatar
2010 31' Classic
Longmont , Colorado
Originally Posted by CrawfordGene View Post
I guess I'm another dufus.
Gene
I been told that once you become a senior you can use that in place of dufus. I resort to that from time to time.
Ken
w7ts is offline   Reply With Quote
Old 11-01-2011, 07:13 PM   #16
CrawfordGene's Avatar
2008 25' Safari FB SE
Crawford , Colorado
Ken
I think "elder" sounds better.
Now what was I looking for when I came into this room and saw the bright shiny thing?
Gene
CrawfordGene is offline   Reply With Quote
Old 11-01-2011, 07:55 PM   #17
Fly at Night's Avatar
2010 27' FB Flying Cloud
Fraser Valley , British Columbia
Bob, Lynn, Twinkie, Kevin, Don, w7, Gene, thank-you for your help. That plastic thing-a-ma-jig wasn't the easiest to work with. A metal plug would have made it so much easier. Anyway, I got it open and the water poured out like Niagara Falls. Then I lifted the pressure release valve - nothing much happened there - don't know if this is how it's supposed to go.
Then I drained the grey/black water tanks - not much in them - have only been using the toilet for occasional wee-wees since coming home from trip. Opened up all the taps - a few sputters - I figure this is normal, since I haven't hooked up to city water or filled fresh water tank since returning home either.
Gene wrote.....You can run the furnace tonight set at 40˚ F. Tomorrow you can finish winterizing. Don't let the dealer scare you. Do it yourself and save some money. RV Antifreeze (it is pink) is available lots of stores. Ours took 2 gallons—I guess that's about 9 liters. There's also a bypass kit for the water pump which makes it all a lot simpler.
The dealer does scare me...and I do a pretty job of scaring myself too. Still intimidated about wrecking something. I have drained all the tanks, opened taps.
Not sure about that bypass valve you mentioned. Furnace is on; I'm set 'til morning. will study John's link, thanks.
I will still take trailer in on Nov. 21. Needs some warranty work - tail-light has been flickering on and off since purchase for one thing.
Can't thank you all enough for helping me through this. One day I hope I'll know as much as you guys, then I can help someone else.
Take the long way home
Fly at Night is offline   Reply With Quote
Old 11-01-2011, 08:26 PM   #18
Goal15's Avatar
Rowlett , Texas
According to Robert Cross' post you can put the AF directly into the freshwater tank and then use the pump to pull it through all the lines once you have blown the lines out rather than messing with bypass kit for the water pump. here's the link to his post
http://www.airforums.com/forums/f458...e-7222-14.html
Goal15 is online now   Reply With Quote
Old 11-01-2011, 09:03 PM   #19
BEWARE of the CAT
w7ts's Avatar
2010 31' Classic
Longmont , Colorado
Make sure that you read some of the winterizing threads. Keep in mind that there are fools like me among us that get along fine by just blowing the air out of the lines VERY thoroughly with an air compressor as per the manual. I only use antifreeze in the sink traps. But then again I have always lived on the edge (not).
Ken
Old 11-01-2011, 10:38 PM   #20
ROBERTSUNRUS's Avatar
Lakewood , California
Images: 18
Hi, you should only use a six point socket on this plug unless you plan on replacing it everytime you remove it.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 11-02-2011, 04:56 PM   #21
1985 31' Excella
Somerset , New Jersey
You could save yourself the aggravation next year by replacing the plastic plug with a brass plug or even better with a valve ( already mentioned I think). Then you just have to open the valve to drain. Best would be a quarter turn valve. A typical twist valve has a seat and rubber gasket that will go bad in time. The qrtr turn valve I think have a teflon ball and are less prone to trouble. I to have had good luck with draining the system and blowing it out and using antifreeze in the traps and WC bowl. Real simple if you have an air compressor available.
Roger in NJ
" Democracy is the worst form of government, except for all the rest "
Winston Churchill, 1947
polarlyse is online now   Reply With Quote
Any hot water pumps out there? 3 Dog Nite Water Heaters, Filters & Pumps 14 07-05-2011 12:38 PM
Help-dewinterizing and no water off freshwater tank bonginator Water Heaters, Filters & Pumps 6 06-12-2011 08:37 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
69 Overlander water tank swap colin57 Waste Systems, Tanks & Totes 2 04-24-2011 08:23 PM
Convert water gravity tank to outside pressure robwok General Interior Topics 15 02-11-2011 12:00 PM
