Old 12-08-2006, 04:11 PM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
dual tank gauges
I have the dual tank set up with a single gauge that is very hard to read as the glass is aged. Rather than replace the dual inlet and control as a whole, anyone suggest a gauge I can add?
What about the magnetic strips that go on the side of the tanks do they work well?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 12-08-2006, 05:58 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Are you perhaps refering to the automatic change-over indicator? If so, the regulator/indicator unit is not expensive and the recommended change interval is 15 yrs. If yours is the standard Fisher regulator, then the date is stamped on the big hexnut on the regulator.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 12-08-2006, 06:37 PM   #3
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I just ordered one for $33 from rvwholesalers
'77 Sovereign Intl 31' CB
Old 12-08-2006, 07:38 PM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks I will check that mine is certainly that old I would imagine.
AIR #005
retired!
Old 12-09-2006, 05:10 PM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Gauge
Here are photos of the Fisher gauge on the dual changeover.
AIR #005
retired!
Old 12-09-2006, 05:11 PM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
any way to replace just the gauge or the glass cover.?
AIR #005
retired!
Old 12-09-2006, 05:52 PM   #7
Excella CM's Avatar
Venice , California
The question becomes why is the window not clear? If there is contamination from water or other degradation from the inside, which I assume is the case, then there is cause to consider replacing the unit. Fisher no longer makes the equivalent, nor do they supply parts because they phased the unit out in 2004. Personally, I like the old Fisher design, but alas it is no more. Rego makes a nice unit that mounts in a similar fashion so that the change-over indicator can be seen from inside the trailer. The rub is that it costs about twice as much as the one commonly carried by RV suppliers. When/if you change the regulator, consider replacing the pigtails that connect it to the tanks. They age too. All of the set-ups work in a similar manner. They are two stage regulators to give accurate pressure control in the supply line and they have two important features: first, when the pressure in the tank you have selected as the supply tank with the hand valve on the regulator runs low, the unit automatically switches to the other tank; second, the regulator shuts off the empty tank line so that it may be removed for refillling without disturbing the supply from the remaining tank. It is prudent to check that the empty tank line is truly shut off when you remove it, since dirt or wear in the change-over may allow it to leak. If that is the case you might need to put a cap on the line or shut off the remaining tank while you get more fuel.
Old 12-09-2006, 11:00 PM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
sun damage to the surface of the lens on the gauge
AIR #005
retired!
Old 01-02-2007, 05:43 PM   #9
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
I Need a Regulator Too
I wondered why my dual tank regulator was not working properly. A dealer installed the new regulator a few years ago when the system was upgraded to the new LP tank valve/fitting. Come to find out the regulator is not a dual tank auto switch-over... Doh! Even though I had the automatic regulator in the old set-up, the dealer replaced it with an inferior unit that I have to manually switch from tank to tank.
Regardless, if I purchase a new unit from RV Wholesalers, do I buy the "bulk" regulator or the "regulator kit"?
Alan, did you find a solution to your problem? A new regulator at ~$35 does not sound too bad.
Thanks, Lucius
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 01-02-2007, 07:30 PM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
well I have seen them but not bought one yet. The regulator and changeover works fine its just the gauge that is hard to read, so I am hanging for now.
AIR #005
retired!
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 06:09 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 08:52 AM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
