Dual propane tap for 2 Honda EU2000i generators
Hi, this is a follow up to many questions I've had to make a tap for a dual propane generator connection. I made up the first of my propane (Central Marine Diesel Tri-fuel kit) conversion but still wanted to use my dual 40# tanks on my AS to feed them. So this is how my project finished.
I looked for a good place to tap the 5/8" feed line and decided that I had a natural point on my unit, just behind the front levelers where my feed line lies. This allowed me to use a tee, branch off to my dual disconnects on the opposite side of the trailer. I used a ball valve to have a secure shut off, just before the disconnects. I used a black pipe tee and reducers to make up the fittings into the disconnects. I used pipe strap U clamps to secure all the fittings below the belly pan. I used the Natural gas grill hose and gas fittings from Lowes. And note, copper line is very expensive now. ($50 for 10 ft.)
The only thing is, Lowes will sell you parts but will not help with any engineering of a gas connections. LIABILITY!!!! Seems that they've been sued. So if your interested in buying the gas parts, they will help but will not tell you how to do ANYTHING with gas lines. Do the research before you start a gas line project. And gas lines require a line cutter, flange tool, and threaded connections need gas line Teflon tape. I did have to make a side trip to a Propane Gas supplier, to get a few parts(male quick connect) that Lowes does not carry and they also will be able to supply most of these parts too.
I have a long summer trip planned for this summer and I wanted to have the capability of A/C when I stop for overnights and 4KW should work. And I will have a Reece retractable 15' safety cable to keep them from straying from home. This may have cost me $150 for parts, so if you need to have a pro install this, expect to pay $300+. And above all, if you do this project, be sure to leak test every joint when you pressure test the new line.
Good traveling,
Fred Bartlett
30' S/O 01 Excella, maple floors in Galley, HA Hitch, Hyd. Disc Brakes, P3 Controller, SS Kit. Bk Splash, LED RL's, 2K/Tri Fuel Gen's & RV on TT
04 Chevy HD, CC, D/A, Curt Magnum V Rec., Full Amsoil Syn.,Dual Filters, ARE, MX Topper with lift Gate Door, Bed Rug, TPS & Bk.up Camera.
