Old 01-01-2010, 02:20 PM   #1
BrockLives's Avatar
1972 29' Ambassador
Currently Camping , Pennsylvania
Dual CO & Propane Detectors - Junk or not?
Does this type of detector work properly? And if so, at what height would it be mounted?
Safe-T-Alert 12V RV CO and Propane Alarm-BROWN*STA-70-742BR
I was under the impression that CO is lighter than air and propane is heavier
BrockLives is offline   Reply With Quote
Old 01-01-2010, 02:37 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Alcohol? My wife monitors that
Carbon monoxide (CO) weighs about the same as air. Propane is heavier.
Originally Posted by The vendor
The gas sensor also detects these explosive gases that are not UL tested: acetone, alcohol, butane and gasoline. The carbon monoxide sensor is very sensitive to CO gas but will not react to most other gases.
Who cares?
The vendor claims the product is rated for RV use. Should you choose to buy it, mount it low for early propane detection.
Tom
Old 01-01-2010, 02:53 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
On trailers equipped with the detectors from the factory they always seem to be mounted near the floor. I have never paid any attention to what brand(s) they were
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 03-25-2010, 11:09 AM   #4
Utahgoldrup's Avatar
1991 25' Excella
Salt Lake City , Utah
Where to Mount Propane/CO Combination Detector?
We do not have a propane or CO detector in our 1991 25ft. Excella... as best I can tell, something was surface mounted right under the main closet in the hallway, towards the floor which I am thinking may have been a propane detector but I don't see where they would have had it hard wired.
I am thinking this would be a great place to put a combination propane/CO detector and then just hard-wire it using the power going to the water pump which is under the trap door in that closet... does anyone have any thoughts, good, bad, etc? If you have a similar trailer, do you know where the propane dector would have been mounted when the trailer was new?
Utahgoldrup is offline   Reply With Quote
Pleasant Surprise with Dual A/C Units on 30 Amp Service panabax Furnaces, Heaters, Fireplaces & Air Conditioning 13 12-07-2010 04:53 AM
Propane/CO detectors juel LP Gas, Piping, Tanks & Regulators 26 10-30-2005 07:10 PM
Reese Dual Cam & pipe Tin Hut Hitches, Couplers & Balls 8 07-02-2004 10:02 PM
New 50 amp Cable~JUNK Navigator Electrical - Systems, Generators, Batteries & Solar 3 04-28-2004 11:32 AM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
