Old 10-21-2018, 04:30 PM   #1
2018 19' Flying Cloud
Eugene , Oregon
Dometic Thermostat Instruction Manual?
I have a 2018 Flying Cloud 19'. I am still trying to figure out how the furnace works - besides just pushing buttons. Yes, I can get the furnace to come on but I don't understand the zones - there would be just one for such a small trailer. And the clock changes with the programing changes. There was absolutely no manual explaining how to use the thermostat - only an installation booklet. I don't know what "HP" means, what the modes are and how they work. Is there a manual that explains how to set the thermostat and how the mode, program, fan modules work?
tjwoods1 is offline   Reply With Quote
Old 10-21-2018, 04:40 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Hi. You only have one zone in a 19. Press the MODE button until you see FURN to run the propane furnace. Then set your desired temperature using the up/down arrows on the right. To see what the current interior temp is press the “INSIDE TEMP” button. The thermostat is in the controller itself.
HP is your heat pump. That is the air conditioner - the unit will run in reverse and produce heat vs cold air. So for heating the trailer you can choose to use the HP or FURN. HP typically only works down to about 45 degrees F, so for colder than that use your propane furnace.
Here is a link to the CCC2 manual:
https://cdn.dometic.com/assets/59/19...9.pdf?att=true
wulfraat is offline   Reply With Quote
Old 10-21-2018, 04:41 PM   #3
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
As far as manuals go... google is your friend. Zones refer to ac/hp. Zone 1 front, zone 2 rear if you have a second unit. HP is heat pump. I find that is this weather auto is best. It will cycle though ac- hp - furnace by itself. Don’t mess with programming.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 10-21-2018, 07:34 PM   #4
2014 23' Flying Cloud
Park City , Utah
Scroll through Zones, they might not be in this order:
1. FURN--Propane Furnace
2. HP--Heat Pump...air conditioner in reverse like Wulf said. Saves propane if you are plugged in, but only down to 40 degrees F, give or take.
3. Auto--If plugged in to shore power, the AC will turn on if interior temp is above your selected set point. Or turn on Heat Pump if interior temp is below selected set point. And then switch to propane if temp gets too cold for Heat Pump to work. If not plugged in, Auto will just turn on propane furnace if temp is below selected set point.
That's really all there is to know. You have only one zone, and who cares what the clock says and who programs their thermostat like you might at home? (Some people say the clock has to be set to the correct time for things to work properly, which is hilarious to me. Your Thermostat could care less what day it is lol.)
Just select what mode you want when you want heat or AC, and call it good.
pcskier is offline   Reply With Quote
Old 10-21-2018, 09:46 PM   #5
2017 28' International
Baileys Harbor , Wisconsin
Honestly I don’t know why AS puts this type of Thermostat in when there is only 1 zone. I have two HPs and ACs and this type of thermostat makes sense. Which I really like. My suggestion is get the book, make a copy and tape it above the thermostat. Or make an instruction on your own like above. It seems more people have trouble understanding this thermostat; especially to start out with. As you use it a few times it gets easier.
Daquenzer is offline   Reply With Quote
Old 10-22-2018, 08:16 AM   #6
Eugene , Oregon
Thanks so much. Really good information here - this forum is invaluable. I’d be lost without everyone’s experience and knowledge.
Old 10-22-2018, 10:53 AM   #7
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
Wulfraat got you answered, but I agree with Daquenzer. We have the CCD on our 23D, but DO miss the manual furnace thermostat, and manual on-off switch and temp controls on our old 19' Bambi.
banderabob is offline   Reply With Quote
Old 10-22-2018, 11:20 AM   #8
CruizinDux's Avatar
Tracktown USA , Oregon
Hey T, I also have a Quick Start manual in the trailer that I can copy scan if you're interested. I didn't see one on-line.
Just one comment re pushing buttons. On our maiden voyage the second night when I turned on the furnace it would fire both the gas furnace AND the AC. Well that wont work. After reading the manual and forums suggestions, I did a hard boot to factory specs. All was well after that. Seems the CCC2 has a bit of history re quirkiness .
When I got home and felt comfortable playing with it more, I believe what I had done was turned the HP fan to low from auto, then turned the unit off. Now when I use the HP I make sure I'm at fan auto when I turn it off.
b
CruizinDux is offline   Reply With Quote
Old 10-22-2018, 11:21 AM   #9
2016 30' Classic
Victoria , British Columbia
A quirk with the operation programming of the heat pump is that if it cannot bring the temp up within a designated period of time, it will call for heat from the furnace. It can be confusing to hear the furnace run, even though it has not been selected on the thermostat.
Camr is offline   Reply With Quote
Old 10-22-2018, 11:51 AM   #10
2016 23' Flying Cloud
Corpus Christi , Texas
Thermostat
Yes, wouldn't it be a wonderful world if Airstream gave people the information they will need to operate their trailer. 😡
2fromtexas is offline   Reply With Quote
Old 10-22-2018, 11:54 AM   #11
CruizinDux's Avatar
Camr, thanks and good to know. In my instance the mode was furn but i also didn't give the HP much time to produce hot air, so stopped the cold flow. Sounds like a possible connection tho and something to remember when running the HP in colder westher. For me the cold boot got me back to furnace firing and HP off.
Old 10-22-2018, 11:55 AM   #12
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
Another quirk occurs when the fan in NOT in the automatic mode. If the fan setting is set to hi, med, or low, the heat pump will also come on when you select the furnace. If you just want the furnace, make sure the fan is set to automatic.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 10-22-2018, 12:13 PM   #13
CruizinDux's Avatar
Bingo, thanks for the confirmation!
Old 10-22-2018, 02:37 PM   #14
2008 19' International
Kingsport , Tennessee
2008 19 ft Bambi international furnace question
I can’t seem to get my furnace to ignite. I have turn the reset switch to reset then off, then back on. Then I flip the very small “off” switch on my thermostat on the wall to the left which I assume turns it on. I then push the actual thermostat lever at the bottom of the thermostat all the way to the right which is the warmest setting. The blower kicks on and runs in the furnace below but can’t see that the gas is igniting to blow out warm air? Is there a significant delay igniting the gas? I do have a gas supply because my stove will ignite with no problem. But it seems my furnace isn’t getting gas. I just bought this AS this summer and just tried the furnace for the first time this week. Any ideas?
ImaTarHeel is offline   Reply With Quote
Looking for intensive Spanish instruction in Arizona or New Mexico guy99 On The Road... 4 12-13-2009 07:25 PM
looking for a reese hitch instruction book or pdf terrance Hitches, Couplers & Balls 3 10-13-2006 05:43 PM
Water heater instruction book Larryb346 Water Heaters, Filters & Pumps 2 07-23-2006 10:44 AM
floor replacement instruction? badcam safari Repairing/Replacing Floor &/or Frame 2 04-03-2004 08:12 PM
towing instruction bhsl8 Towing, Tow Vehicles & Hitches 3 05-12-2003 02:13 PM
