Old 07-07-2016, 07:36 PM   #1
turnerstream's Avatar
2005 25' Classic
New Braunfels , Texas
Dometic Refrigerator Flame Going Out on Highway
When traveling on the Interstate at or near 70 miles per hour, our refrigerator is shutting off while running on propane. We noticed this when we kept seeing the 'Check' light illuminate after traveling on Interstate 40. On slower back roads and while camping we aren't having any issues. I've removed the burner windshield, cleaned the burner/orifice area, and reinstalled the windshield, but we keep having this issue. Any thoughts on what else I should check or anything I can do do better protect the flame? I think after 30 seconds of trying to relight, the refrigerator stops and illuminates the 'Check' light. Is that correct?
Corey
Turnerstream.com
turnerstream is offline   Reply With Quote
Old 07-07-2016, 07:59 PM   #2
1974 25' Tradewind
Calgary , Alberta
I know this is going to foment a flood of indignant replies that "We never shut off our propane and it's okay!" but I think you'll find that if you look at any trailer towing publications anywhere, they will all tell you to shut off your propane tanks at the tank valve while traveling.
For instance:
Manitoba Insurance pamphlet (page 8)
BC Things you need to know
Just sayin'. I'm sure that you could find a recommendation from every state and province's DMV, to shut off the propane while traveling.
The fact is that if your fridge is worthy of the name, and you have it and the freezer reasonably stocked with food items and beverages, it will keep itself cool enough through a day of towing that there is no problem shutting the thing off while on the move.
Edit:
According to this link, it's illegal to travel with the propane (tank) valves open. That means you would be charged and possibly be found negligent if any problem were to occur due to the valves being open while you're going down the road. Any lawyer for a third-party injury or property damage claimant would definitely have a field day.
Alumineer is offline   Reply With Quote
Old 07-08-2016, 12:43 AM   #3
1986 31' Sovereign
Miami , Florida
Don't know where the author of the article you linked to got her information but it is perfectly legal, at least in Florida, to travel with the propane on and the refrigerator operating on it. I know of no U.S. Jurisdiction that prohibits the practice other than a handful of vehicle tunnels (I.e. The Chesapeake Bay Bridge-Tunnel).
Most of us do it. But everyone is free to make their own decision.
I suspect that towing at 70 has a lot to do with the reefer flame blowing out. You may need to extend the baffling or add a screen behind the door louvers.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 07-08-2016, 08:13 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Why even have a refer if you shut it down while traveling? You might as well have an ice box.
Old 07-08-2016, 08:13 AM   #5
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Not sure if your unit was part of the recall to add extra shroud. Search for your fridge.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-08-2016, 08:25 AM   #6
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I had the same problem on my preowned 2008 Classic 25fb when I purchased in 2013. I had the recall performed which added a larger shroud around the burner unit. Luckily this fixed the issue.
Kelvin
KJRitchie is online now   Reply With Quote
Old 07-08-2016, 12:42 PM   #7
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I had this problem for a couple of years- I'd stop while on the road, and half of the time find the propane flame had gone out. Problematic, at the least, if you want to keep things in the fridge from warming up. Tried all of the suggestions - cleaned the burner assembly and chimney, put a wind blocking layer of furnace filter material inside the exterior fridge door, etc. I started thinking about replacing the thermocouple, and while examining what would be involved, I found that the connection in the thermocouple line (it's inside the exterior fridge door) had come loose - it was finger tight, and a bump would probably cause a loss of voltage and shut down the gas flow. Tightening with wrenches fixed that problem - it's been a couple of years with no further problems.
No WD, but a great DW!
robert claus is offline   Reply With Quote
Old 07-08-2016, 01:37 PM   #8
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
X
X2
Here is what the recall shroud looks like on our fridge.
ID:	266263   Click image for larger version
PFC
but Iím the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Old 07-08-2016, 01:46 PM   #9
gecko's Avatar
2009 28' International
Pacific Palisades , California
Kelvin
Anybody have a link to this specific recall? I can only find the link for older models for the unit working on electric, and nothing for a larger baffle recall.
Thanks!
gecko is offline   Reply With Quote
Old 07-08-2016, 01:58 PM   #10
1974 25' Tradewind
Calgary , Alberta
I did some more reading and I may stand (sit) corrected, at least partially. I did find out some interesting stuff.
  • Nova Scotia, Manitoba, and New Jersey prohibit travel with open propane cylinders
  • At least one state (Virginia?) has a maximum of 2, 20 pound tanks
  • Ferry services definitely prohibit open propane cylinders.
We've always traveled with closed propane tanks; we pre-cool the fridge before leaving on a trip and we haven't had any issues with food warming up during a day's travel. As noted, you're free to do what you like...
Old 07-08-2016, 05:52 PM   #11
GCinSC2's Avatar
Did you check here? http://www.dometic.com/USA/Support/D...l-Information/
S/OS #001
Old 07-08-2016, 07:14 PM   #12
2005 25' Classic
Thanks for the responses. I'll look into the recall and the thermocoupler fitting.
Old 07-08-2016, 09:22 PM   #13
2011 30' Flying Cloud
Arvada , Colorado
We travel with our refrig operating on propane and from time to time the flame will blow out. I agree with others that a day of travel all not adversely impact keeping your box cold if it happens to be off.
Jack46 is offline   Reply With Quote
Old 07-08-2016, 09:31 PM   #14
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I know there have been some Dometic recall's over the years to add a larger baffle to deal with blowouts of the flame on the road. My 2001 Safari had that problem and the dealer built a larger baffle which fixed that problem. Some folks have actually fabricated some small furnace filters to fit on the door. However those need to be removed when parked to allow proper airflow into the refrigerator compartment.
Jack
Jack Canavera
STL Mo.
AIR #56
Fridge going out on the highway Kosm1o Refrigerators 19 08-02-2013 07:43 AM
hydro flame won't flame 123f5 Furnaces, Heaters, Fireplaces & Air Conditioning 2 11-12-2010 10:05 PM
Dometic flame-out Mr.Sovereign Refrigerators 11 04-22-2008 05:00 PM
Dometic: Is my flame out? ipso_facto Refrigerators 2 04-09-2006 11:48 PM
Flame out on Refrigerator When Traveling jcanavera 2001 Safari 8 12-07-2002 11:44 AM
