Old 11-05-2015, 10:35 AM   #1
lucca53
lucca53's Avatar
1973 31' Excella 500
2004 22' Safari
2006 25' Safari
napa , California
Dometic 2452 refrigerator help
Hi all I'm out of ideas works on AC great, propane lights up little green meter in middle but does not cool anything,,,,I have cleaned burner and orffice so any other ideas would be very helpful thanks
lucca53 is offline   Reply With Quote
Old 11-05-2015, 10:31 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
What does the flame look like? Has the flu been cleaned?.
Perhaps you have a bad thermostat on the gas side. What is the gas pressure at the refer test port? Should be 11" of water column. Does the flame vary when you adjust the thermostat?
Old 11-06-2015, 10:42 PM   #3
lucca53
lucca53's Avatar
2004 22' Safari
2006 25' Safari
napa , California
Hi TG the flu has not been cleaned refer is still in trailer didn't realize that there is 2 thermostats and the flame doesn't seem to change when i turn up thermostat.I don't have a way to test pressure column which i would have to bring in to shop if i can't get this going...but now you give me another test to do i will check to se if thermostat has a short....thanks for your response....
Old 11-07-2015, 07:20 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You may not see a visible change in the flame but there should be an audible change. Listen closely at the back of the refer.
Old 11-07-2015, 09:42 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
The thermostats is used for both gas and electric.
If the unit cools on electric the problem is in the gas section. You say the flew has been cleaned. There should be a tubulator in the flew to cause the flame to wash against the sides of the chimney. Is that still there?
Cool the unit down on electric to the lowest setting, a day or more. Once cooled have someone put it on gas while you watch the flame and then have them set it to a colder setting. You should hear the flame sound change as the thermostat calls for cooling. If not the control board or the gas valve may be the issue. Put a volt meter across the wires leading to the gas valve and do the raise thermostat test. If you see voltage as the thermostat goes up the control board is good and the gas valve may not be responding.
2004 Excursion 4x4
Old 11-07-2015, 10:03 AM   #6
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
I do not have your model of Dometic, so am offering my experience on a 2006 Dometic in a 23 foot Safari.
Although the propane or electric options both worked fine, I had an Ammonia leakage from a broken tube in the unit. It was a poorly welded tubing defect. I not only smelled it when it began to leak on a camping trip, but a yellow residue is left at the source of the leak.
Maybe this is of no help, but nobody has brought this option of your situation.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 11-07-2015, 10:46 PM   #7
lucca53
lucca53's Avatar
2004 22' Safari
2006 25' Safari
napa , California
Thanks Ray whoa a ammonia leak that must have been no fun,Howie the flew was not cleaned but I will try to listen to the flame so far the flame seems to be staying on at one setting there is no change no matter how i turn the heat setting...
Dometic 2452 refer problems amazingwoody General Repair Forum 15 07-20-2013 05:17 AM
HELP!! Bought new Dometic refrigerator--How do I remove the RM60? Shelby Copeland Refrigerators 6 07-17-2012 07:55 PM
Help with Dometic refrigerator John Geisen Refrigerators 23 07-19-2010 07:25 AM
Dometic Refrigerator help needed UK-Airstream Refrigerators 8 05-25-2006 04:57 PM
