Old 03-21-2013, 08:30 AM   #1
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Does the Micropulse Monitor Panel Monitor LP?
Hello,
I'm looking at purchasing my 1st AS and I notice the monitor panel has labels for LP1 and LP2. Does it really have sensors for the LP tank?
Kelvin
Old 03-21-2013, 08:39 AM   #2
2008 16' Safari
Destrehan , Louisiana
Micro pulse makes several different monitors and sensors. Just because it says LP1 and LP2 does not mean it's hooked up or even active.
FYI - my Micro Pulse has never worked right. Fresh water, grey water and battery monitor work fine. The black water has never worked. I had it repaired twice before I just gave up.
I wouldn't give much weight as to what kind tank monitor system is installed. None of them are very good.
dlb435 is offline   Reply With Quote
Old 03-21-2013, 08:47 AM   #3
2011 27' FB Classic
Masontown , West Virginia
Yep
Kelvin
Not certain about older models, but our '11 does have sensors on both tanks.
AND, they work very well, unlike some of the holding tank and water tank sensors.
Have a great time!
Bill
Bill & Dorothy Reeves
2011 27FB
2016 F250 6.2L
TAC # WV-2
MountaineerStreamer is offline   Reply With Quote
Old 03-21-2013, 09:38 AM   #4
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Our 04 has it for both LP's and that along with the battery are the only ones that work. The tank monitors do nothing.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 03-21-2013, 02:54 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
It depends on the Airstream. Classics have float gauges in the LP tanks, while other models do not (unless this has changed).
The float gauges can be read directly by looking at the gauge where it is mounted at the top of the LP tank, and they also have sending units that connect to the Micropulse monitor. They are accurate and are a great convenience.
Old 03-21-2013, 03:20 PM   #6
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
Exact same story here too.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
