Old 04-09-2014, 10:47 PM   #15
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
If I understand the above post correctly then the valves on both tanks should be in the open position? Or should one tank be closed and the other open then when you see red open the closed valve?
TinCan
graysailor is offline   Reply With Quote
Old 04-09-2014, 11:40 PM   #16
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
How I do it - turn junction valve to primary (first) tank and then open that tank fully. You should see green. Then, move junction valve to center position and slowly open tank two. You should still see green, When the primary tank runs low the red collar will appear but you still have gas pressure.
Once red, turn junction valve towards second tank and close empty primary tank. Remove and refill.
SeeMore is offline   Reply With Quote
Anyone know anything about this?? pinktrailer Airstream Lifestyle 10 08-08-2011 05:23 PM
Propane tank sending units SteveH LP Gas, Piping, Tanks & Regulators 6 11-17-2008 08:57 PM
Does anyone know anything about putting safety skids on axles? 1959newbie Axles 7 05-01-2006 05:59 AM
Propane Tanks with Sending Units adchisholm LP Gas, Piping, Tanks & Regulators 6 08-06-2005 10:23 AM
Does this number mean anything to anyone? Gigawatt WBCCI Forum 10 06-22-2005 05:39 PM
