Old 11-20-2010, 10:27 PM   #1
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
Does anybody have a single propane tank setup? Pics?
In the original ad for my 1958 flying cloud, it has a single tank setup. The current setup is a dual tank rack. I have never needed to use my second tank on my globetrotter, which gets me thinking. I kind of like the simplicity of a single tank.
Anybody have pictures of your single tank setup?
ddstech is offline   Reply With Quote
Old 11-21-2010, 07:54 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I am installing that single tank set up this week...on the Curtis. Somewhere in the forums I had asked the same question and received some great answers. The problem rotates around fastening the tank and the regulator. Its a work in progress...let me know if you have some ideas too.
Old 08-12-2015, 10:01 AM   #3
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
I know this thread is very old, but am contemplating the same on my 55 FC. Anyone come up with a good solution? Need a way to secure bottle. Also wondering if my dual regulator will function with one line capped?
BambiTex is offline   Reply With Quote
Old 08-12-2015, 04:31 PM   #4
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
40# Worthington bottle, 1968GT
ID:	245325   Click image for larger version
ID:	245327   Click image for larger version
ID:	245329   Click image for larger version
ALUMINUMINUM is offline   Reply With Quote
Old 08-20-2015, 09:47 AM   #5
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Thanks.
Old 09-05-2015, 10:13 AM   #6
1958 18' "Footer"
Sebastopol , California
I just fabricated a single mount this last week. Sorry no time for a picture today. But I promise a picture and information tomorrow night or Monday.......
50s Aluminum is offline   Reply With Quote
Old 09-06-2015, 07:57 PM   #7
1958 18' "Footer"
As promised. The black powder coated bracket was purchase on Amazon.com. They come as a pair, they are advertised as propane mounts for a forklift. The rest was fabrecated by a good friend. We used scrap steel and aluminum plate. Total time 3 hours. Tools used were a welder, band saw, grinder, drill, and a plasma cutter. Most DIYers won't have all of these tools but you get the idea. Unfortunately me ipad can only add one picture at a time so I'll have a few posts.
Old 09-06-2015, 08:03 PM   #8
1958 18' "Footer"
A closer picture. Like I said we just did this. I'll be cleaning it up and painting in a couple of weeks.
Old 09-06-2015, 08:11 PM   #9
1958 18' "Footer"
While we were at it we incorporated a under frame spare tire mount. I don't know if I'll us it but it only required drilling one additional hole in the angle iron before welding the upright channel to it. Welded a nut on a piece of 1/2" thread all and drilled a small piece of channel.
Old 09-06-2015, 08:18 PM   #10
1958 18' "Footer"
Last picture from the underside. The aluminum plate will get trimmed out with some 1/2" door edge molding I found. I placed the rod for the spare to hopefully make sense of how it'll work. Lastly if you felt the need to lock up your PP tank you could easily drill the tank "foot" to lock it underneath...... out of sight. Hope this helps someone.
Old 09-18-2015, 10:53 AM   #11
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
This looks great!
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 12-30-2015, 09:03 AM   #12
ragin-cajun's Avatar
1961 16' Bambi
Malden , Missouri
Yay for the updates on this thread! I am planning to go to a single vertical tank as a winter project, and I was about to ask "how" until I found this thread. Thanks for the great pics and descriptions.
ragin-cajun is offline   Reply With Quote
Old 01-03-2016, 05:46 AM   #13
1961 16' Bambi
Malden , Missouri
Any others with a single-tank setup? Ideas on how to build one or sources for materials?
Old 01-29-2016, 05:19 PM   #14
1961 16' Bambi
Malden , Missouri
I got mine done today. Next up is the new regulator. Click image for larger version
Name:	ImageUploadedByAirstream Forums1454113111.457952.jpg
ID:	256514Click image for larger version
Name:	ImageUploadedByAirstream Forums1454113134.611820.jpg
Propane Tank Noise jrk247 LP Gas, Piping, Tanks & Regulators 20 01-16-2017 08:22 PM
Single Waste Tank Question sailorii Waste Systems, Tanks & Totes 2 06-13-2010 12:56 PM
Getting the most from your propane tank ArveeBob Base Camp 0 09-15-2009 01:38 PM
Convert to single LP tank in SoCal? pauly g LP Gas, Piping, Tanks & Regulators 5 06-29-2008 10:40 PM
Propane tank charlief1317 Airstream Motorhome Forums 14 01-04-2003 08:00 PM
