Old 08-29-2003, 12:20 PM   #1
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Display light question
Almost continually the black water display reads 2/3 full. I use the clean out that's supposed to squirt fresh water into the tank; fill about full (look down the stool) and let it all out. It will be okay for a little while. Then back to 2/3 full.
I suspect that toilet paper from the stool slides over the contacts. It this an Airstream "tragic flaw" or what?
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 08-29-2003, 02:07 PM   #2
My black water indicator light has never worked properly. Mine shows full most of the time. Sometimes it shows empty right after I empty the tank. I have tried several methods to remedy this problem and have been unsuccessful.
I was recently at an Airstream dealership looking at a used 2000 25 foot excella and the black water indicator light said 3/4 full. I asked the salesman why because I assumed the tank was empty at the dealership. He looked me straight in the eyes and said, "does your indicator light work properly?" Of course, I had to say no! He went on to tell me that since Airstream went to this current "system" that the tank indicator lights do not work properly.
I just live with the problem, and know from years of experience that our family of 4 can go at least 7 or 8 days without emptying the black water tank if we need to.
Clark
csimingt is offline   Reply With Quote
Old 08-29-2003, 03:52 PM   #3
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Maybe I'm lucky
That's one thing on my trailer that has worked well from day one.
John W. Irwin
WBCCI #9632
Old 08-29-2003, 04:01 PM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I've never owned a trailer where the black water indicator worked correctly. Once I start using the tank, paper and other waste tend to foul the sensors. Personally I could care less since the old eyeball looking through the open toilet valve as its flushing is the most accurate way to know how your tank is doing.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-29-2003, 05:57 PM   #5
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I hate to say this but my 30+ year old sensor works fine, on both black and fresh tanks.
They do have a new sensor that is non intrusive into the tank, that I saw on the factory tour. Not sure if it is infrared or what. It was a sensor that was stuck on the side of the tank with adhesive.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 08-29-2003, 06:35 PM   #6
HP9K's Avatar
Here's a tip I picked up somewhere that cleaned my black tank well enough to get my sensor working again.
After you dump the black tank, fill the tank 1/2 to 2/3 full with clean water, add a squirt of dish soap and then add a 10 pound bag of ice cubes thru the toilet and hit the road.
As you drive, the ice cubes will float on top of the water and slosh around, knocking the little bits and pieces of trash off the sides of the tanks and sensors. After your next dump, the tank should be nice and clean and hopefully the sensors will work again.
Worked on both my Airstreams - neither worked when I bought them and this little trick brought the sensors back to life.
HP9K is offline   Reply With Quote
Old 08-29-2003, 07:13 PM   #7
Pahaska's Avatar
Hays County , Texas
I have that new sensor and it has worked very well. I think it is capacitive, There are a row of sensors stuck on the outside of the tank and the display goes by percentages of tank depth.
John W. Irwin
WBCCI #9632
Dent and replacing light fixtures imeynstein Lights - Interior & Exterior 5 03-30-2004 01:56 PM
Recessed lamp question uwe Electrical - Systems, Generators, Batteries & Solar 2 03-11-2004 08:45 PM
Light Fixture Covers (plastic) ke4lkq Electrical - Systems, Generators, Batteries & Solar 4 01-16-2004 05:28 PM
help me see the light wheel interested Our Community 1 11-17-2003 07:34 AM
Tail Light on '62 Overlander Deppdog Electrical - Systems, Generators, Batteries & Solar 1 08-16-2003 08:21 AM
