Old 07-29-2019, 07:10 PM   #1
1994 30' Excella
Mt. Tremper , New York
Detecting a Propane Leak
Hi All! I'm hoping that I may be able to get some advice about a propane leak that we have. There is a distinct propane smell outside of our Airstream near the furnace and inside under the kitchen sink (also where the furnace is. We have sprayed all of the connections and no bubbles. I even had a RV repair person come out to check and they said there were no leaks at the connection points. We installed a new LP/CO in November and it is not detecting a leak...but I trust my nose. Is there any advice you might be able to give to finding the source of the leak? Appreciate any help!
lakagyeama is offline   Reply With Quote
Old 07-29-2019, 07:22 PM   #2
Baby Zeppelin's Avatar
2018 28' Flying Cloud
Suwanee , Georgia
Your profile does not disclose what kind of Airstream you have. If it is a modern one with two propane tanks and an auto-switchover valve that is normally displaying green flags then shut off all your propane appliances and your propane tank valves. The valve should still show green. Let it sit overnight. Flags still green? Probably no leak, as the pressure has remained in the lines between the tank and all appliances.
Erik & Carol
Suwanee, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
Baby Zeppelin is offline   Reply With Quote
Old 07-29-2019, 09:17 PM   #3
1994 30' Excella
Thanks for the response! We have a 1994 Excella. It does have an automatic switch over but I don't see a green/red indication on ours. That being said, it is pretty fragrant outside and inside our Airstream. Mostly outside but certainly when i open the kitchen cabinets (that is where the propane lines run to the furnace and the stove. No leak on the stove connection but I do have a concern that the flames on the gas stovetop have started showing orange/blue instead of just blue.
Old 07-30-2019, 06:30 AM   #4
Suwanee , Georgia
Wonder if the gas valve on your stove is leaking. Don't know how to test it, other than by splashing sudsy water on it. You might see if you can disconnect and cap of sections of the propane plumbing and see it you can localize the leak. Propane operates at very low pressure beyond the regulator, for what it's worth.
Erik & Carol
Suwanee, Georgia
Old 07-30-2019, 10:05 AM   #5
2017 16' Sport
Fort Wayne , IN
Trust your sniffer
I know in the natural gas industry there are actual meters that sniff for natural gas. If I were you, I would call around for furnace technicians that may have such a device.
In the meantime, if you havenít already, either shut off your tanks or at least try and isolate the leak. Maybe shut off furnace valve first. Smell will linger for sometime though. Makes it difficult to know if you remedied it by isolating a particular line or appliance. I have seen gas valve blocks have leaks that were very hard to detect.
Personally, you alls safety is first.
They add the smell into gas so you can detect it. At least thatís what I have been told. Trust your sniffer.
Good luck, safe travels,
Kevin
KRPS is offline   Reply With Quote
Old 07-30-2019, 11:19 AM   #6
2016 25' Flying Cloud
Nanoose Bay , British Columbia
See my recent thread - you may not have a leak after all. Check your propane tank level ...
http://www.airforums.com/forums/f287...it-196039.html
Gary Nijman
2016 Flying Cloud 25 FB Twin
2018 GMC 3500 Denali Duramax
gnijman is offline   Reply With Quote
Old 07-30-2019, 11:50 AM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The almost empty tank does sometime provide a more pungent odor in propane appliance even though you have no leaks. Also check those propane pigtails that come off the tank into the regulator. I've had those leak twice over the course of 15 years at the small end due to the deterioration of the hose at the small coupling.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-30-2019, 01:36 PM   #8
1981 31' Excella II
New Market , Alabama
Propane leaks are so hard to find. I am having some issues and I think I am going to have to pressurize the lines with an air compressor and do some soap testing.
Perry
Old 07-30-2019, 06:03 PM   #9
2007 22' International CCD
Donít go to more than 4-5 pounds of air pressure on the lines. Gas valves on the appliances donít like lots of pressure. 11 inches of water is about 0.4 pounds per square inch IIRC. Be careful.
Old 07-30-2019, 09:22 PM   #10
2017 27' Flying Cloud
Sioux falls , South Dakota
Gas leaks are serious.
Hire a certified gas contractor. The contractor has the knowledge and equipment to certify your system. Money well spent as opposed to injury or even death. It is best to shut the tanks down ASAP.
Sitesee is offline   Reply With Quote
Old 07-31-2019, 06:08 AM   #11
JDG
Riveted
JDG's Avatar
2018 33' Classic
Charleston , West Virginia
Get a gas sniffer. Here is one from Rigid tools on Amazon. Works very well and much better than your nose. Approximately $150.00 which is going to be less than the service call.
RIDGID 36163 Model micro CD-100 Combustible Gas Detector, Gas Leak Detector
JDG is offline   Reply With Quote
Old 08-02-2019, 01:04 AM   #12
1994 30' Excella
Thank you- how can you tell how much pressure is in the lines?
Old 08-02-2019, 01:07 AM   #13
1994 30' Excella
Thank you- this is great since Iím not getting any nibbles!
Old 08-02-2019, 06:34 AM   #14
Suwanee , Georgia
The pressure is very low, on the order of about Ĺ psi. Therefore it's measured using a column of water.
See http://blog.goodsam.com/what-do-you-...-water-column/
Erik & Carol
Suwanee, Georgia
Propane Cooktop Stove, Propane Oven from 1971 Sovereign colleenkay Airstream Classifieds 0 09-14-2016 03:06 PM
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 08:56 AM
Newbie Advice on Propane and Propane Accessories Socal1 LP Gas, Piping, Tanks & Regulators 1 07-15-2013 12:36 PM
Detecting / Sealing Leaking Rivets Without Removing Inner Skin HolyRoller Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-10-2011 03:33 PM
