Old 09-29-2016, 02:16 PM   #1
Dedicated Propane Regulator per appliance... Really?
I'm designing the propane setup for my new build. I'm installing a Dickinsen Sig 9000 propane fireplace and an Suburban two burner stove. The Dickinsen manual says to use and individual regulator for each appliance. I see the beauty in this but I guess it means I can't have my auto switching Camco dual stage regulator. which switches between tanks. Frankly I'm not sure how to design this so that I don't have to go out and swap out tanks.
1. Can I just connect two tanks together?
2. Do I really need dedicated regulators? Do RV's typically do this?
Ahhhh! Brain fry!
Any help appreciated.
From the manual.
http://www.sigmarine.com/manuals/SIG...ace-2011-1.pdf
"NOTE: Each low pressure propane appliance should have its own low
pressure regulator and fuel supply line as shown on the propane locker
diagram on pg. 9.
Reasons for having a separate low pressure regulator for each appliance:
1. The ABYC Standards state- 1.7.2 – Each appliance shall be served by a
separate low pressure regulator and supply line that shall originate inside the
cylinder locker. We recommend you follow the ABYC standard.
2. The regulator only serves a very low pressure of gas, through a small 3/8”
gas line, and depending on the distance, 1 regulator for 2 appliances
may starve the burners of gas for 1 appliance.
3. Some older appliances do not have thermocouples on the burners, and if the
gas valve on that appliance was left in the “on” position, gas would leak while
using the heater or any other appliance and could result in a serious explosion. "
Name:	Screen Shot 2016-09-29 at 3.10.09 PM.png
bass-o-matic is offline   Reply With Quote
Old 09-29-2016, 02:29 PM   #2
dznf0g's Avatar
Oswego , Illinois
Some appliances require lower than 11" water column...and some require the 11"
From the factory you have the regulator at the tank (11") and the stove has its own second stage drop regulator under the stove top. That is universal, as far as I know. I don't know anything about your fireplace, but I suspect it is the same situation. The furnace, fridge and water heater still need 11".
-Rich-
Clipper, Land Yacht, Electronics Dedicated Power Supply masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 19 08-01-2016 04:42 PM
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box betsy Airstream Classifieds 0 09-19-2014 11:01 AM
Who owns a dedicated tow vehicle? Advice? andreasduess Tow Vehicles 17 05-14-2014 08:14 PM
Dedicated positive wire for solar? JimmyT Generators & Solar Power 8 05-22-2010 10:16 AM
Really, Really, Really Hot swebster Airstream Motorhome Forums 8 11-16-2003 08:46 PM
