01-02-2013, 03:24 PM
#41
2005 19' Safari
GLENDALE
, AZ
Today, 01/02/13, propane was $2.10 per gallon at the Costco in north Phoenix (19001 N. 27th Ave, Phoenix, AZ 85027-5036, I-17 & Yorkshire).
01-02-2013, 03:50 PM
#43
1981 31' Excella II
New Market
, Alabama
Well if you get a new bulk storage tank for the house make sure you get a bottom tap valve put in. Roomer has it that you can fill your tanks off your home tank with a liquid line. Of course, this is purely hypothetical and no one would actually do such a thing. Alternatively you could hook your trailer to a spur line off the main tank. Now I just need a propane powered generator and I would be set.
01-02-2013, 04:04 PM
#44
Roomer has it that you have to have a lower pressure in the tank you are trying to transfer fuel to by opening the spit or bleeder valve and it helps if the tank you are transfering the fuel from has been in the sun (warmer) and the one you're putting the fuel into in the shade (cooler). But as you said, this is purely hypothetical and no one would actually try doing such a thing.
Enjoy,
Paul Waddell
01-02-2013, 05:27 PM
#45
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
Last summer I filled my 40#ers while camping at the Air Force Academy. They charge $3.45/gal there and I thought that wasn't bad at all. They wouldn't fill because they needed to be re-certified. Off to a distributer nearby who certified them for me and filled them for $3.15/gal. So the $.30 is the convenience factor. Not bad in my opinion.
Here at home they all fill by weight.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
01-02-2013, 06:20 PM
#46
1975 31' Sovereign
Houston
What was the certification procedure? and the cost for it. How long did it take?
thanks
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
01-02-2013, 06:28 PM
#47
1993 34' Excella
2001 25' Safari
Beaufort
, North Carolina
I have been carrying a 30# tank around for a week, forgeting to have it filled until today. Found a place called Ferrellgas in Wilkesboro,NC. Filled 7.2 gal @ $2.50 for $18.00 and $1.26 in tax for a total of $19.26...I call that a deal
01-02-2013, 08:10 PM
#48
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
Hi DD. Certification is simply a physical inspection. OPD valve = good, no rust on a steel can = good. Paint in good cond. on steel can = good. Aluminum can is just an eyeball inspection. All good = 5 more years.
Roger in NJ
TAC - NJ 18
01-27-2014, 04:08 PM
#49
2005 19' Safari
1
I agree, I don't think they fill them to 100% capacity. I think it is closer to 75-80% as well. This leaves room for expansion.
Costco will fill them.
01-27-2014, 04:21 PM
#50
Airstream - Other
Bosque Farms
, New Mexico
They'll also watch for small cracks along the welds. This happens often enough when people tighten down clamps on a steel collar way too much, bending the collar so much that cracks form along the weld.
Lynn
ACI Big Red Number 21043
01-27-2014, 04:25 PM
#51
Ottawa
, ON
Costco in Kingston, Ontario charges thirteen dollars and some change. It's the least I have ever seen for a 30-lb tank.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
01-27-2014, 04:28 PM
#52
Airstream - Other
Bosque Farms
, New Mexico
The 80% thing is true of all of these cylinders in the United States.
What trips people up?
1. Believing incorrectly that a 30-pound cylinder can be filled only to 4/5ths of that amount (24 pounds) because of the 80% rule. Nope. The 30-pound figure, which is calculated from the WC marking on the collar, includes the 80%, so when the cylinder is filled to the 80% limit, the propane will weigh in at 30 pounds.
2. Believing incorrectly that the smaller "bbq" cylinders, when bought via propane exchange, contain 15 pounds of propane because of the 80% rule. Nope. They fill to 15 pounds because they can make more money that way. Those cylinders generally have a capacity of 20 pounds, not 15 pounds.
Lynn
01-27-2014, 05:07 PM
#53
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
Just got one filled last week. Here in central NJ it was $25.
Roger in NJ
TAC - NJ 18
01-27-2014, 05:20 PM
#54
Rivet Idiot
1999 34' Excella
On The Lake
, Georgia
$21.00 at KOA in Tifton Ga last Thursday.
Annette
01-27-2014, 05:28 PM
#55
2011 27 FB International
sarasota
Paid $3.49/gal at a local U-Haul in Sarasota, Fl last week. Filled 15 gallons for two 30 pounders. Even in Florida we need propane for heat.
01-27-2014, 05:32 PM
#56
1977 Argosy 24
Milltown
, Wisconsin
In west central Wisconsin there is a propane shortage. They will not fill any cylinder under 100 pounds. If your grill is out you are out of luck. Some LP dealers are totaly out of LP. If you want your house 500 gal tank filled, you will only get 200 gallons max, if you are lucky and it's over $5.00 a gallon!!
01-27-2014, 07:51 PM
#57
Central
, Mississippi
$78 to fill two empty 40lb empty tanks after a very cold night. Woke up grumpy, left the propane store grumpy.
01-27-2014, 08:18 PM
#58
2006 25' Safari
St. Augustine
I got a 30# tank filled for $13.00 on a half off day at Campingworld with the Sams Club membership in October. Here they offer half off twice a week.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
01-27-2014, 09:44 PM
#59
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
I filled one of Lucy's 30# tanks yesterday at U-Haul in Jacksonville, Florida. It was $3.99/gallon. It took 7.2 gallons for $28.73 + $2.87 sales tax. The tank full cost $31.60.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
01-28-2014, 06:30 AM
#60
Airstream - Other
Bosque Farms
, New Mexico
I also read that prices elsewhere have spiked, and that even prices here in the southwest will rise as a result of the shortage elsewhere. I'm hoping we've got enough on hand to make it through the remainder of the winter and spring. It has not been particularly cold here, relatively speaking.
Lynn
