Old 01-02-2013, 03:50 PM   #43
1981 31' Excella II
New Market , Alabama
Well if you get a new bulk storage tank for the house make sure you get a bottom tap valve put in. Roomer has it that you can fill your tanks off your home tank with a liquid line. Of course, this is purely hypothetical and no one would actually do such a thing. Alternatively you could hook your trailer to a spur line off the main tank. Now I just need a propane powered generator and I would be set.
Old 01-02-2013, 04:04 PM   #44
rideair's Avatar
Roomer has it that you have to have a lower pressure in the tank you are trying to transfer fuel to by opening the spit or bleeder valve and it helps if the tank you are transfering the fuel from has been in the sun (warmer) and the one you're putting the fuel into in the shade (cooler). But as you said, this is purely hypothetical and no one would actually try doing such a thing.
Enjoy,
Paul Waddell
rideair is offline   Reply With Quote
Old 01-02-2013, 05:27 PM   #45
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Last summer I filled my 40#ers while camping at the Air Force Academy. They charge $3.45/gal there and I thought that wasn't bad at all. They wouldn't fill because they needed to be re-certified. Off to a distributer nearby who certified them for me and filled them for $3.15/gal. So the $.30 is the convenience factor. Not bad in my opinion.
Here at home they all fill by weight.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 01-02-2013, 06:20 PM   #46
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
Question
What was the certification procedure? and the cost for it. How long did it take?
thanks
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 01-02-2013, 06:28 PM   #47
1993 34' Excella
Beaufort , North Carolina
I have been carrying a 30# tank around for a week, forgeting to have it filled until today. Found a place called Ferrellgas in Wilkesboro,NC. Filled 7.2 gal @ $2.50 for $18.00 and $1.26 in tax for a total of $19.26...I call that a deal
dheflin is offline   Reply With Quote
Old 01-02-2013, 08:10 PM   #48
retired USA/USAF
2001 30' Excella
Hi DD. Certification is simply a physical inspection. OPD valve = good, no rust on a steel can = good. Paint in good cond. on steel can = good. Aluminum can is just an eyeball inspection. All good = 5 more years.
Roger in NJ
TAC - NJ 18
Old 01-27-2014, 04:08 PM   #49
T1NCAN's Avatar
2005 19' Safari
1 , Washington
I agree, I don't think they fill them to 100% capacity. I think it is closer to 75-80% as well. This leaves room for expansion.
Costco will fill them.
T1NCAN is offline   Reply With Quote
Old 01-27-2014, 04:21 PM   #50
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
They'll also watch for small cracks along the welds. This happens often enough when people tighten down clamps on a steel collar way too much, bending the collar so much that cracks form along the weld.
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 01-27-2014, 04:25 PM   #51
Ottawa , ON
Costco in Kingston, Ontario charges thirteen dollars and some change. It's the least I have ever seen for a 30-lb tank.
Old 01-27-2014, 04:28 PM   #52
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
The 80% thing is true of all of these cylinders in the United States.
What trips people up?
1. Believing incorrectly that a 30-pound cylinder can be filled only to 4/5ths of that amount (24 pounds) because of the 80% rule. Nope. The 30-pound figure, which is calculated from the WC marking on the collar, includes the 80%, so when the cylinder is filled to the 80% limit, the propane will weigh in at 30 pounds.
2. Believing incorrectly that the smaller "bbq" cylinders, when bought via propane exchange, contain 15 pounds of propane because of the 80% rule. Nope. They fill to 15 pounds because they can make more money that way. Those cylinders generally have a capacity of 20 pounds, not 15 pounds.
Lynn
WBCCI 21043
Old 01-27-2014, 05:07 PM   #53
retired USA/USAF
2001 30' Excella
Just got one filled last week. Here in central NJ it was $25.
Roger in NJ
TAC - NJ 18
Old 01-27-2014, 05:20 PM   #54
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
$21.00 at KOA in Tifton Ga last Thursday.
Annette ...... Canopener Party Planner
AirHeadsRus is offline   Reply With Quote
Old 01-27-2014, 05:28 PM   #55
2011 27 FB International
sarasota , Florida
Paid $3.49/gal at a local U-Haul in Sarasota, Fl last week. Filled 15 gallons for two 30 pounders. Even in Florida we need propane for heat.
airron is offline   Reply With Quote
Old 01-27-2014, 05:32 PM   #56
1977 Argosy 24
Milltown , Wisconsin
In west central Wisconsin there is a propane shortage. They will not fill any cylinder under 100 pounds. If your grill is out you are out of luck. Some LP dealers are totaly out of LP. If you want your house 500 gal tank filled, you will only get 200 gallons max, if you are lucky and it's over $5.00 a gallon!!
ventport is offline   Reply With Quote
