Old 01-02-2013, 09:06 AM   #15
CanoeStream's Avatar
St. Cloud , Minnesota
Originally Posted by Skater View Post
$22-$24 the last few times I had it done for a 30-lb cylinder.
That's right in our price range using a gritty local equipment rental business. Closer to $30 at gas stations and U-Haul.
5 meter Langford Nahanni
Old 01-02-2013, 09:07 AM   #16
rogerdodger's Avatar
Fresno/Clovis , California
I filled my two 30#ers for $52 here in central Cali.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 01-02-2013, 09:28 AM   #17
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Filled 1 30# for around $30 in Sebring FL, a week before Christmas at a BP service station.
Alan
Old 01-02-2013, 09:34 AM   #18
2008 31' Classic
Lakewood , Colorado
4 year old 40lb Tank over filled
Could a someone over fill a 40 lb tank? Yes: My 40lb'er pressure releif value was releasing fumes the day after he filled my tank. Temp. in the 40's both days. At the recommendation of the retailer that filled the tank, I took it to a Suburban Propane dealer for a possible valve replacment knowing very well that the new style tank couldn't be over filled. Well guess what, it can be and was. Thank God I hadn't openned the tank valve as we were just preparing to leave on an extended trip. So all this great life saving measures taken to save our hide from poorly trained propane dispensers doesn't hold much water. The tank was bled off by the service tech at Suburban Propane and everything was fine. The retailer did weight the tank as he filled it as I watched him but something wasn't right. So future fills will be made at a more experienced location rather than a retailer that rents truck and trailers and sells propane also.
Hap3 is offline   Reply With Quote
Old 01-02-2013, 09:45 AM   #19
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The OPD is supposed to prevent overfilling of the tank. If the tank was overfilled I would question the operation of the valve. A good operator should know when the valve is going to activate based on the weight of the tank and it's contents. If the valve fails to function correctly, it should be replaced.
Richard
Old 01-02-2013, 10:02 AM   #20
2008 31' Classic
Lakewood , Colorado
40# over filled
The valve was checked at the time and was fine. Also the tank has been refilled several times since this incident in Febuary of 2012 and hasn't failed.
Old 01-02-2013, 10:33 AM   #21
1988 32' Excella
Robbinsville , New Jersey
But if you opened the valve that would have bled off some of the propane.
This actually seems too common at least in warmer weather, cold propane going into tank then expanding and leaking from the new "safer" valve.
Old 01-02-2013, 10:59 AM   #22
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Even if their main line of business is renting trucks and trailers, they still have to be licensed to dispense propane. If you're concerned that this location is not doing it right, I would suggest that you find out what State department regulates the sale of propane in the state where you got the tank filled, and lodge an official complaint. If improper procedures are being followed, the location may find their license pulled as a result.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-02-2013, 11:12 AM   #23
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Funny - the $22-$24 I quoted is at a gas station and a campground (a campground that actually charges a fair price for propane...whodathunkit?).
Originally Posted by CrawfordGene View Post
They don't fill the tanks because of the possibility of expansion when it gets hot. I believe it is illegal to fill them. I believe they can only fill them to 80 or 85%. That comes out to 7 gal. for a 30 lb. tank.
Correct, but Blue Rhino and the like are underfilling even more than that.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 01-02-2013, 11:14 AM   #24
Central , Mississippi
The new style tanks actually have 4 valves.
The twist valve
The OPD
A check valve
And an over pressure vent valve.
The 1st three are all in series.
The vent is separate and once 'vented' is suspect.
My tanks OPD valves slam shut when full and the fill pump deadheads.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-02-2013, 11:17 AM   #25
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Just had a 30# filled at Pismo Coast Village in Pismo Beach CA. I removed it, placed it in front of our trailer, it was picked up and a few minutes later it came back full.
$30.00
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 01-02-2013, 11:42 AM   #26
80% of a 30-pound tank is 24 pounds of propane. At 4.3 pounds per gallon (at 70F) that's only about five and a half gallons of propane. Seven gallons would be approximately 30 pounds of propane, which is about right for a 40-pound tank at 80% full.
WBCCI #1105
TAC LA-4
Old 01-02-2013, 11:45 AM   #27
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
BBQ cylinders have a marking on the collar for WC. For BBQ cylinders, the WC is generally around 47.x, indicating that the cylinder, when full, can contain 47.x pounds of water. If you multiply that number by .42, you'll get the capacity of the cylinder in pounds of propane. It'll be at or very close to 20 pounds.
Now check the "net weight" on the plastic sleve of a trade-in BBQ cylinder (Blue Rhino and others). You'll see that it is generally 15 pounds. In other words, they'll filling only to partial capacity.
On the positive side, these cylinders all have OPD valves and are (supposed to be) within the qualification date. When folks come here with a cylinder that cannot be filled (no OPD, out of qualification, damaged, whatever), I have them do the trade-in. And then remind them that it's no problem to have their new cylinder refilled by a dealer; i.e., no need to do yet another trade-in when that one's empty.
Lynn
WBCCI 21043
Old 01-02-2013, 11:47 AM   #28
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
The 80% figure is already factored in, so if the WC figure indicates (after math; see my post above) that it'll contain 30 pounds of propane, then you don't subtract 20% and then fill; rather, you fill to 30 pounds.
Lynn
WBCCI 21043
