Old 01-21-2006, 07:15 AM   #15
1989 29' Excella
West Liberty , Kentucky
Copper compression fittings vs. flare fittings
Thanks everyone for the input. Sounds like I better stay with flare fittings.
phippsto
phippsto is offline   Reply With Quote
Old 01-21-2006, 07:49 AM   #16
jimmickle's Avatar
2000 31' Land Yacht
While not necessary with copper like it is with steel, double flares provide a stronger, less likely to split flare. Personally, I always use double flares, and never have leak problems. It only takes an extra minute to do the double flare.
jimmickle is offline   Reply With Quote
Old 01-21-2006, 08:32 AM   #17
Johndigbydog's Avatar
1966 22' Safari
Eagle Lake / Eastport , Florida / Maine
Wardinbb- I think you make an EXCELLENT point! That's what this forum is all about, alerting others and trying to help one another out....the GOOD SAM creedo John
Johndigbydog is offline   Reply With Quote
Old 01-21-2006, 08:35 AM   #18
lewster's Avatar
Naples, FL , Hood River, OR
Tom W,
While single flares work, the current national gas codes spcify double flares for LP use, especially in TT's and MoHo's. Just trying to keep you around the orum for a while!
Old 01-21-2006, 09:02 AM   #19
Wardinbb's Avatar
1964 24' Tradewind
Big Bear Lake , California
Gotta ask and see
Gentlemen,
I would certainly appreciate seeing the image of a double flare and the tool that creates it.
Thanking you in advance for your kind attention to this matter.
Ed
Wardinbb is offline   Reply With Quote
Old 01-21-2006, 09:49 AM   #20
Wardinbb's Avatar
1964 24' Tradewind
Never mind
I found it. So actually the flare is a 2 step process to create the joint. Here's the PIC I found illustrating the double flare. So to adapt one's present flare tool to a double flare, the first step inserts are all that are necessary?
Ed
Name:	Dbl Flare.jpg
Old 01-21-2006, 10:33 AM   #21
Images: 59
Originally Posted by Wardinbb
. . . the first step inserts are all that are necessary?
Ed
Yes. The height of the large end of the first step button is the gauge for setting the height of tubing above the flaring bar.
Old 01-21-2006, 05:50 PM   #22
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Times change
Originally Posted by lewster
Tom W,
I understand completely. Thank you for your concern. Karma to you, sir for sharing today's code.
Tom
Old 01-21-2006, 06:44 PM   #23
lewster's Avatar
Tom,
You are most welcome!
Old 01-21-2006, 06:46 PM   #24
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
My Overlander is home for the weekend. I think I will double check the lines going to the gas lamp before it goes back to storage. It never hurts to be sure, and what looks like a flare fitting to me may be another compression fitting.
Old 01-22-2006, 06:11 PM   #25
Wardinbb's Avatar
1964 24' Tradewind
Terry, Did ya light a match...
after ya turned the stove on to see if it leaked? I think your idea is good, it can't hurt to find out and it could hurt plenty someday if its not right. Let us all know what you found. It would be a very bad thing to have a repeat condition like that from an original install.
Ed
Old 01-22-2006, 06:28 PM   #26
lewster's Avatar
One other 'pearl of wisdom' from the RV 'Powers-That-Be': Always use a back-up wrench when working a flair fitting. In order of preference: flair wrenches, standard wrenches, crescent (adjustable) wrenches. Please, NO VISEGRIPS!!
Be safe out there!!!
Old 01-22-2006, 06:41 PM   #27
Wardinbb's Avatar
1964 24' Tradewind
Speaking of tools
I found the double flare or double lap adapters here: http://stores.ebay.com/USA-Excess-Su...QQftidZ2QQtZkm
If you're interested in adding to an existing flare tool set-up that you have, these will top it off. I shall seek concurrance from Don as to quality and price.
Ed
Old 01-22-2006, 06:58 PM   #28
Wardinbb's Avatar
1964 24' Tradewind
The link above for the adapters wasn't quite direct, so scroll down on the page you reach to see this item: ROTHENBERGER ROFLARE 45 DEG FLARING ADAPTER
Ed
Copper vs. PEX ckeysor Fresh Water Systems 19 07-11-2007 12:03 PM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 08:54 AM
Antenna Wiring niftypkg Electrical - Systems, Generators, Batteries & Solar 1 09-22-2002 01:04 PM
Copper Canyon (Barranca del Cobre) Pahaska On The Road... 0 07-25-2002 07:14 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
