Old 04-18-2016, 06:58 PM   #1
2014 23' Flying Cloud
2015 28' Flying Cloud
Kalamazoo , Michigan
Cooking with AS propane
Will be heading out on a prolonged trip and will be using my Weber Q grill. I've finally figured out how to run it off my trailers tanks. Anyone have an idea how fast I may burn through my propane? Will likely be running the furnace at night as well. I can't image the use rate is any different compared to the 1lb canisters. Each canister would last 3-4 days, roughly.
mwilliamsmd is offline   Reply With Quote
Old 04-18-2016, 07:14 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Biggest users will be water heater and furnace. You are right, grill would be similar to use on small bottles.
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 04-26-2016, 07:12 PM   #3
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
I have a Coleman Roadtrip grill i use with the 1 lbs tanks and can get some 6-10 or more grill times before i have to change them out..
I have a refill part and use my 20lbs grill tank to refill them with. Keep a couple on hand and don't use the needed gas from TT tanks. One 20lb tanks will refill two 1lbs at least 19 combined times for a whole lot less money than buying them (1lb tanks) in the store.
http://www.ebay.com/itm/like/1618929...&ul_noapp=true
I paid over 17 bucks for it several years ago.. now they are 7.. figures..
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 04-26-2016, 08:34 PM   #4
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
how do you connect grill to AS gas?
Did you get a special adapter to connect your Weber to the AS tanks? I have the gas quick connect, which I thought would be my back up if I ran out of propane for the grill. Then I did, and tried to connect, only to find that my grill hose did not fit the AS quick connect. I didn't have that back up plan thought out too well!
RAH is offline   Reply With Quote
Dutch Oven Cooking azflycaster Stella's Kitchen 435 Yesterday 11:10 PM
Cooking Outside Edie Stella's Kitchen 75 09-05-2011 06:00 PM
Cooking Pots John Stella's Kitchen 51 03-18-2008 10:57 PM
Cooking and Culinary Sub-forum Jimandrod Stella's Kitchen 43 03-10-2008 07:08 PM
Cooking on wheels w/oapaddle Off Topic Forum 7 06-02-2007 07:33 PM
