Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 06-29-2008, 07:25 PM   #1
pauly g's Avatar
1960 22' Safari
Oceanside , California
Convert to single LP tank in SoCal?
I'm thinking of converting to a single 30# LP tank, and putting two batteries on the toungue of my 1960 safari. The gas lasts for years without refilling, and there is never enough battery capacity. We don't use much heat here in the San Diego area. I don't like to disturb the vintage look, but it would be more practical. Any thoughts?
pauly g is offline   Reply With Quote
Old 06-29-2008, 07:58 PM   #2
BDandTTs's Avatar
2005 22' International CCD
Phoenix , Arizona
Images: 49
Although we live in the cold North, and often camp when temperatures are around freezing, we've made a similar conversion and are very happy with it. Our propane tank is only 20 lbs., but still lasts a long time even when using it for heating. We've mounted a 1 lb. portable propane bottle using a 'steak saver' as an emergency backup, and also found that Trojan 6Volt batteries have the same footprint as the original equipment Group 24 12Volt battery -- what an improvement in capacity. The 6Volt batteries are taller, but were easily accommodated in our setup. Here is a link to a description and some photos, http://www.airforums.com/forums/f448...tml#post454094.
Bob, Dianne, and Tess the WFT
BDandTTs
Bandit #14576 (WDCU/AIR)
https://www.RWChatelain-Woodturner.com
BDandTTs is offline   Reply With Quote
Old 06-29-2008, 08:18 PM   #3
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Airstream Funeral Coach
Citrus Heights , California
Images: 35
Pauly;
That sounds like a plan to me! I almost always travel with one empty propane tank on the Excella.I have a separate battery for my fridge! 3 total.
BTW-- since when is Oside in the San Diego area??
When I was stationed at Pendleton in the late 60's no one wanted to claim it!!!
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 06-29-2008, 09:11 PM   #4
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
I wonder if you could cut the bottom off a tank and stack two batteries in side... The top would go over the top to cover and protect the batteries and have the look of both tanks.... JUST AN IDEA!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 06-29-2008, 09:29 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I like having 2 propane bottles. When one runs dry while camping it switches over and I fill it after the weekend is over. Most of the places that I camp are miles away from the nearest place to refill. The last time I had a tank run dry was Memorial Day Weekend. We were snowed in at Hawley Lake in Arizona. The closest place to refill was about an hour away if the roads were open. Without a second tank we would have been in serious trouble.
Have you thought about moving the bottles forward enough to mound the two batteries between the tanks and the shell?
Richard
Old 06-29-2008, 10:40 PM   #6
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
I considered this as well.
You would have to make very sure that you couldn't short things out as you installed or un-installed the batteries.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
SoCal Brand-Newbie gemspark Member Introductions 8 11-15-2007 09:34 PM
Need to convert rear twins to single bed desmits 1984 - 1989 Sovereign 4 07-23-2007 08:14 PM
New SoCal Member - Length ? LifeguardTwr Member Introductions 10 01-14-2007 07:59 PM
New SoCal Owner silverhawk25 Member Introductions 15 01-06-2007 05:19 AM
Classic 34 Owners in SoCal?? GeeJay Our Community 4 01-18-2006 05:43 PM
