07-03-2016, 12:07 AM
54 Flying Cloud
1967 20' Globetrotter
1954 22' Flying Cloud
Grand Rapids
Considering new Fiberglass Propane Tanks
They're 50% lighter, won't explode and are corrosion proof. Anyone have these yet?
07-03-2016, 03:32 AM
1995 25' Excella
xxxxx
, xxxxxx
I considered them until I read on the Viking FAQ page that they had to be recertified every 5 years.
10-22-2016, 01:48 AM
Goliad
According to the US code DOT-SP 12706 the recert is every 10 years.
The Frommes
Goliad, Texas
The Birth Place of S. Texas Ranching
WBCCI #6256
10-22-2016, 04:36 AM
Loretto
, Ontario
Interesting. I assume its 50% lighter than steel.
10-22-2016, 05:32 AM
2016 23' International
Centennial
What is involved with recertifying them? The lower weight and fireproof features are appealing.
Steve "Centennial Man"
10-22-2016, 05:42 AM
Mantua
, Ohio
Wasn't there a recall on those a few years ago? I'd check that out, otherwise seems like a good idea.
10-22-2016, 06:04 AM
2009 25' FB International
2018 27' Globetrotter
Tavares
IIRC they can only be filled at certain filling stations which are not readily available. Otherwise great idea!
10-22-2016, 06:17 AM
Goliad
I fill my own tanks from my house tanks but the recall bothers me. Going to check that out as well
The Frommes
Goliad, Texas
WBCCI #6256
10-22-2016, 06:36 AM
Retired.
, At Large
http://www.phmsa.dot.gov/cylinder-recall
10-22-2016, 07:13 AM
1954 25' Cruiser
Bern - Thun
, Berner Oberland
Links the gas bottle in the middle comes a gas tank, right, the aggregate for the vacuum toilet.
10-22-2016, 07:58 AM
1976 31' Sovereign
Oswego
IMO not a good idea as have had tank come loose drag on pavement 2 times, firmly fastened? No covers. One ruined banana wrap. Luckily hose held tank from going under AS. These are 40# aluminum tanks, no damage to them either time except one surface scratches not deep so will easily sand out w/1000 wet or dry sand paper. If fiberglass would they break?
10-22-2016, 03:26 PM
1954 25' Cruiser
Bern - Thun
, Berner Oberland
Hans627
I had the plan to install a larger gas tank. But if the tank is empty, I need to find an LPG filling station to refuel with the trailer somewhere. The gas bottle here I can redeem on any campsite or in a shopping center. You pay once a deposit and then the price of gas for the newly filled bottle.
Greetings from Switzerland - Werner
10-22-2016, 03:40 PM
Originally Posted by Cruiser6483
Hans627
Werner, how much gas do they put in tanks in Switzerland? In the US the standard propane tank holds 20 lbs.
But if you use the "exchange" program, the 20 lb tank is only filled with 15 lbs of propane.
I'm curious if they do the same short-fill in Switzerland.
10-22-2016, 06:11 PM
1954 25' Cruiser
Bern - Thun
, Berner Oberland
markdoane
For individuals, the amount of gas does not really matter. From 300 kilos (= 661,387 lbs), you need a permit, so for Commercial Transportation. Normal installation in a trailer or in a motorhome = space for 2 x 11 Kg (24.2508 lbs) gas cylinder, inside or outside, you then exchanges the empty to full. In the same size, there are also gas tank bottles (for safety reasons the capacity is only 80%). In my motorhome Renault Master L "Pössl" the tank bottles are filled from the outside. They must refuel itself.
In my Cruiser is a normal 11 kg steel bottle to replace, plus a 20 Kg (44.09246 lbs) Gas tank with outside filling. In my "pictures" is the floor plan with marked gas tanks.
Greetings - Werner
10-22-2016, 10:49 PM
1954 25' Cruiser
Bern - Thun
, Berner Oberland
Sorry...
"In my Cruiser is a normal 11 Kg FIBERGLASS bottle...."
10-26-2016, 08:21 PM
2004 30' Classic
San Antonio
Viking propane cylinders were not affected by the recall. Lite Co of Tn was the culprit.
10-26-2016, 09:11 PM
2010 25' FB Flying Cloud
Davenport
, Iowa
With OXYGEN, STEEL AND ALUMINUM TANKS are filled to 2200 lbs., the FIBERGLASS TANKS could be filled to 3000 lbs. My concern to the tank would be temperature and solar exposure and "bruising" that could occur from road debris if not protected.
The Vapor pressure in a propane tank is 128 PSIG @ 80 degrees.
mike
10-26-2016, 09:15 PM
Davenport
, Iowa
The information was from PROPANE CARBS.COM
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
31 ft Airstream; NEW frig, NEW hot water tank, 2 NEW propane tanks, in good cond
eBay Watch |
Airstreams on eBay |
3 |
06-24-2017 02:19 PM |
eBay Watch |
0 |
07-05-2013 07:00 AM |
Does old fiberglass insulation equal new fiberglass insulation?
Petethefeet |
General Interior Topics |
7 |
11-14-2010 12:16 PM |
Fiberglass LP tanks
sumsmug |
LP Gas, Piping, Tanks & Regulators |
0 |
10-29-2009 05:15 PM |
Propane Tanks - New OPD Needed?
montanaandy |
18 |
06-17-2002 12:11 PM |
