Old 07-10-2013, 02:46 PM   #1
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Connecting gas range
I've scored my new Seaward range and am going to install it this weekend. I can do flexible copper with a flared fitting as the old range was, but I'm wondering if there is some kind flexible gas appliance hose that is okay to use in an RV- it would make the install a little simpler. Thanks
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 07-11-2013, 02:43 AM   #2
crabbey1's Avatar
1976 Argosy 22
Pasadena , California
Images: 33
Send a message via AIM to crabbey1 Send a message via Skype™ to crabbey1
I am sure that you could use one of those yellow flex gas lines but the issue, as I understand it, is that you want all connections to be outside of the trailer. In case there is a leak, it will dissipate on the exterior as opposed to filling the trailer.
Anyone else?
crabbey1 is offline   Reply With Quote
Old 07-11-2013, 06:58 AM   #3
aftermath's Avatar
Spokane , Washington
Isn't the last connection made right at the stove? That would shoot a hole in your hypothesis, as good as it was.
aftermath is offline   Reply With Quote
Old 07-11-2013, 08:02 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Not really. If you trace all of the propane lines, you'll probably find that there are no joints inside the Airstream; every "T" or joint is outside. The only connection inside is right at the appliance, and from the appliance to the floor penetration is all one piece of tubing.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-11-2013, 09:43 AM   #5
1974 Argosy 20
Kooskia , Idaho
The flexible yellow gas lines are not made for the vibration of a trailer and are not approved or legal in them. They are for occasional movement of an appliance in a home situation.
Old 07-11-2013, 09:57 AM   #6
cameront120's Avatar
1972 25' Tradewind
How do they account for the movement in the propane line on boats when the range is in a gimballed setup? I believe that they use a flexible hose.
North Vancouver, BC
Old 07-11-2013, 10:12 AM   #7
American Boat and Yacht Council (ABYC) standards are not quite the same as Recreational Vehicle Industry Association (RVIA) standards.
WBCCI #1105
TAC LA-4
Old 07-11-2013, 10:14 AM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yup, it is LP rated hose not hard pipe.
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-11-2013, 01:56 PM   #9
crabbey1's Avatar
1976 Argosy 22
Images: 33
My point was simply to minimize any connections inside of the trailer. Of course there will be a connection at the appliance. Just make sure it is damn good... And have an LP gas alarm.
Old 07-14-2013, 03:35 PM   #10
Globie64's Avatar
Images: 18
After I posted this, I looked online and found that the only way was to use copper and flare fittings.. the only way that I could find. So, that's what I did, got to use my flare-maker, tested the heck out of it. There are three connections, two at the valve and one at the range. Now I'm wondering if I should have put the valve under the coach and just had a straight shot to the range?
Old 07-14-2013, 04:06 PM   #11
crabbey1's Avatar
1976 Argosy 22
Images: 33
Where did you put the valve? Inside the living space? That is a no no. All valves should be under the trailer on the exterior. From what I understand, it is just a safety issue.
Old 07-14-2013, 04:10 PM   #12
Globie64's Avatar
Images: 18
Ah, okay. In residences, we have to put the shut off near the range, and I did that with this, accessible under the sink. The previous setup had the same connections, a reducer from half to 3/8" and then into the range, but the old range had the valve under the cooktop.
Old 07-14-2013, 05:24 PM   #13
aftermath's Avatar
The shutoff is at the propane tanks. Why add another? Years ago I added a water heater to my tent trailer. I "T-eed" off of the existing propane line under the trailer and ran a flexible copper tube to the heater. I used flair fitting everywhere and the old flaring tool that my grandfather left me worked like a champ. I found that "flexible" copper isn't really all that flexible. You have to be very careful with this stuff. You can only bend it so many times.
Old 07-14-2013, 05:47 PM   #14
crabbey1's Avatar
1976 Argosy 22
Images: 33
I added a valve under the trailer to each appliance so that I can troubleshoot any future leaks by just running gas to each appliance seperately.
