Old 07-14-2013, 06:39 PM   #15
cameront120's Avatar
1972 25' Tradewind
Peter, you could always splice in another shutoff in the line outside the trailer so that you don't undo all the work that you've already done. I believe that both my range and furnace ran off the same propane line which had a shutoff on the outside of the trailer, however, the furnace had a shutoff at the appliance as well. This made sense to me, because the furnace could be shut off during the warmer months without interrupting the flow of propane to the range.
North Vancouver, BC
Old 07-14-2013, 11:27 PM   #16
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
The trailer has a valve at each appliance- most are under the trailer, they are the originals. The fridge has one accessible inside the access door. The old range had one built in, under the cook top. I talked to a tech guy at Seward and they said to put it at the range, not underneath. I understand not wanting to have fittings buried inside the trailer. I would never install a fixture, plumbing or gas, without a shutoff.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 07-14-2013, 11:29 PM   #17
Globie64's Avatar
Images: 18
Hey Cameron, I thought the issue was having additional fittings inside the trailer that could jiggle apart over time or something. I'd kind of rather avoid having another valve under the coach because it's vulnerable to moisture. I could splice in another valve, true, maybe I should? I actually have an extra...
