Old 09-24-2014, 07:58 PM   #1
2014 30' International
College Station , Texas
Coleman NXT Grill
I have connected my NXT Coleman grill using the quick connection in the front of my 2013 30 FT International. I purchased an adapter for the grill so I could connect to a propane bottle. I can not get the grill to ignite. Tanks have ample fuel. Any suggestions??
PRGairstream is offline   Reply With Quote
Old 09-24-2014, 08:08 PM   #2
Wayward's Avatar
Cary , North Carolina
The gas pressure coming out of the quick connection likely is regulated (low pressure). If you still have the regulator on your gas grill, it will probably not work.
The regulator on the grill is expecting high pressure input from the 1lb Coleman style propane can. You'd probably have to tap into the high pressure side of the Airstream tanks or replace the grill's regulator with an adjustable valve.
If you have already removed or bypassed the regulator on the grill, there may be a shutoff somewhere.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Trailer Mount Grill??? 66Overlander LP Gas, Piping, Tanks & Regulators 22 05-01-2016 05:11 PM
Anyone tried Meguiar's NXT Wax? starcraft Exterior Restoration Forum 13 11-16-2015 06:49 AM
Got a Cobb Grill for Christmas! Stefrobrts Our Community 31 02-28-2007 04:54 PM
front MH grill repair Astrodokk Airstream Motorhome Forums 10 03-27-2004 04:09 PM
