Old 09-15-2010, 12:40 PM   #1
Jephellis's Avatar
1959 18' "Footer"
Carbondale , Colorado
Images: 48
CO detector sounded this weekend!!!
Hi All,
I installed a furnace last year, it vents through the wall to outside air. I'm always nervous to go to sleep with it on, but tried it this weekend and my battery powered CO detector went off at 4am! I regularly check my connections with gas leak detector and they all seem fine but there's one joint that I can't reach because it's sucked up within the belly, could that be it?? I feel silly letting one of the connection be out of reach...Maybe I should re-do? Also any suggestions for newer pipe options, the copper seems too rigid for me to drive around on the bumpy roads in the mountains????
THANKS!!!
Jeff
Jephellis is offline   Reply With Quote
Old 09-15-2010, 12:52 PM   #2
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
A CO detector won't give an alert for propane. If you're seeing a CO alert, either water or heater exhaust fumes are recirculating into the trailer. This can be due to a flue problem, obstructed vent (wasp nests and cobwebs, the critters do love propane) or you had a window ajar and the fumes were blown/drawn back in.
Check your flues for obstructions.
TX-16
Dave Park is offline   Reply With Quote
Old 09-15-2010, 02:44 PM   #3
knunut's Avatar
2007 20' Safari
2016 26' Flying Cloud
Chgo. N.W. Burb's , Illinois
Low Battery's ?
knunut is offline   Reply With Quote
Old 09-15-2010, 02:52 PM   #4
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I have had the CO detector go off when parked at a rest stop amid idling 18-wheelers. I was in the middle of a short nap and that is a cruel way to be awakened.
Fumes, such as spray paint or thinner can poison the sensor. That happened to me recently when I did a lot of work in the trailer. I'll replace the detector before furnace time rolls around again.
John W. Irwin
WBCCI #9632
Old 09-15-2010, 03:18 PM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Always scary when alarm goes off, middle of the night the monoxide detector went off on boat, nothing was on and vents were open, only after reading about CO detectors did I find that some are sensitive to diesel fumes.
AS put in three CO, propane and smoke alarm. Smoke alarm saved us when some wiring caught on fire at a quick connect plastic ignited due to arcing.
I Test each one before a trip now.
Our CO is in the bedroom, if the genset doesn't set it off, nailpolish along with paint, varnish or furnace fumes might have blew back into trailer thru refrigerator vent, if they are close.
Old 09-15-2010, 06:18 PM   #6
Splitrock's Avatar
Sioux Falls , South Dakota
We had one at home. Wife's hair spray set it off every day. We moved it to the upstairs hall. Then the deodorant spray set it off. We moved it to the top shelf. Then anything aerosol set it off. Threw the #!*%+\ thing in the garbage.
Old 11-06-2010, 09:30 AM   #7
Houston International
2005 25' International CCD
Houston , Texas
Send a message via ICQ to tj_ia
Our co2 monitor saved our behinds last night. All of us (wife, dogs, me) were sleeping unusually hard and Werent moving at all. Turns out the furnace vent was obstructed by soot, and if it weren't for that detector we would have slept ourselves away. I'm buying a new monitor asap, just to be sure. The old one is going in a frame and will be hung on my super hero wall of fame.
Tim J
Houston, TX
tj_ia is offline   Reply With Quote
Old 11-06-2010, 11:33 AM   #8
Splitrock's Avatar
Which brand and model furnace? What will the remedy be?
Glad you posted.
Gary
Old 11-06-2010, 11:34 AM   #9
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
CO detectors can save lives, but they can also cause a lot of aggrevation with false alarms. (Like one morning a few years ago at the Grand Canyon in January one morning when the temperature was -5 )
Careful inspection of any combustion sources is warrented whenever the detector goes off.
I recall a few times some years ago when winter temperature inversions in Phoenix were causing smog levels that were setting off domestic CO detectors.
snake is offline   Reply With Quote
Old 11-06-2010, 02:39 PM   #10
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
Re-consider this abbreviated answer:
Originally Posted by knunut View Post
Low Battery's ?
Jephellis, you said your CO alarm went off at 4AM. Were you dry camping and running entirely off your trailer battery? What's the age and condition of that battery? Are you relying on the Univolt or your tow vehicle to charge that battery?
Don't panic -- it happens to a lot of us. If the CO detector is one installed by AS, it is likely it has the built-in 'battery minder' function which sounds an alarm whenever the battery voltage reaches a set value. This is supposed to prevent damage to the battery and allow you to provide additional power so that the refrigerator, heater and hot water heater will continue to function (they all require nominal 12 volts DC to operate their printed circuit boards).
I suggest you acquire a decent digital AC/DC Volt/Ammeter and get someone to show you how to use it to check the current draw in your unit or have someone do it for you. Also check the output of your Univolt and learn about the limitations of the charger circuit therein.
It may have been solvents or fumes, but that needs verification by a more sophisticated CO measuring device than what is found in a home or RV detector. Your local fire department might have one; your local gas or oil service company definitely will have one. Regardless of who you have measure it, get the actual CO levels checked when your monitor is going off. And for peace of mind, check your battery's voltage when the alarm is going off, too. It just might be time to get a new battery...
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 11-06-2010, 05:37 PM   #11
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Ours has gone off numerous times. Never during the day, but usually around 4-5 AM ! it will sound off. This happens in the summer when all that is running is the air conditioner. Winter time when all that is running are the electric heaters. It will happen at least once it seams every camping trip. I now have a switch on it so it can be turned off when it sounds off. I have given up trying to figure it out.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 11-06-2010, 06:39 PM   #12
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Hem, stupid question...
Mine went off while I had a friend visiting. The friend has limited sight and uses a dog... the dog was sitting right by the CO detector, and she farted. That apparently set off the alarm.
So... any pets that sleep near floor level?
Did you have chili for dinner?
Paula
Old 11-06-2010, 07:37 PM   #13
cclarkego's Avatar
1966 24' Tradewind
Oak View , California
Images: 8
I heard something from my PO, that dogs can set off the propane alarm. One time mine went off when my dog was laying next to it. Scared the **** out of him and me too.
cclarkego is offline   Reply With Quote
Old 11-06-2010, 08:32 PM   #14
Certainly Blessed
rebelstand's Avatar
1971 27' Overlander
Waiting to Escape.... , Somewhere between sanity and insanity ... on the brink of both.
No...no....no...
Paula
Please don't tell me that ..... we will never get a good night's sleep again. We have two of the gaseous dogs either side of the Mississippi/Pacos/Rio Grande!
Nicki
TAC OK-42
Come See Minnie Mouse at the TAC Walt Disney World Fort Wilderness Rally
http://airstreamingdreaming.blogspot.com
"Get busy livin', or get busy dyin'." - The Shawshank Redemption
rebelstand is offline   Reply With Quote
How to use my detector Tagalong LP Gas, Piping, Tanks & Regulators 1 08-11-2010 09:56 AM
Lp Detector davidz71 LP Gas, Piping, Tanks & Regulators 7 12-12-2005 09:44 AM
Lp Detector PARKS1963 LP Gas, Piping, Tanks & Regulators 3 09-15-2005 08:37 PM
Sounded like some deals to me.... j54mark Our Community 9 09-25-2003 05:36 PM
Gas Detector winner Airstream Motorhome Forums 2 07-02-2002 03:59 PM
