Old 07-04-2015, 05:56 AM   #1
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Chilling discovery
About 2 years ago I replaced my MEC auto change over regulator with a newer 2 stage model.... I was smelling propane and determined it was from the old regulator.
Since that change, I have had a steady decline in the cooling performance of my fridge only on lpg. Recently the temp spiked. I removed the whole thing, cleaned the flue, checked the thermistor, cleaned the seals, everything was perfect, including the flame.... Or so I thought!
On a whim I hooked up my manometer, and to my shock, I measured only 6" watercolum pressure! Not having an rv dealer handy, I removed the adjustment cap to find the adjustment totally maxed out! I removed the spring, stretched it out which applied more pressure against the diaphragm. I re assembled the whole deal and pow up to the 11" my appliances need. Since then the fridge is back to normal. Even in 90 degree heat the fridge is keeping cold. I reinspected the flame, and sure enough it is still clear blue like it had been, but the shape and height is now different!
I might suggest if you are experiencing warm temps on lp, get a gauge and check out your pressure, this was absolutely my problem! I naturally assumed that since I replaced the regulator it would be perfect set to 11"..... Not the case!
Years ago, I installed a computer fan inside the fridge, and on the coils on the back. Combined with a cleaning, I'm happy with my old Dometic again!
Hope my little discovery keeps your libations cold!
Old 07-04-2015, 07:01 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
A redneck check is to, on a quiet day, open the fridge access door, and stand close with it on LP. You should be able to hear a light "roaring" sound from the burner. I've been "burned" before by flames that looked good, but really weren't.
Old 07-04-2015, 07:06 AM   #3
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
A new part is identical to an old part until it proves itself. Thanks for the post.
NavyCorpsman is offline   Reply With Quote
Old 07-05-2015, 05:15 AM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Ironically I could hear the flame with the bad regulator setting, it always made a slight roaring sound!
Looking at the flame before it was a clear blue, wide on the burner, now it is still clear blue, however much narrower an taller in the flue.
Old 07-05-2015, 05:50 AM   #5
Well Preserved
1993 21' Sovereign
That is interesting. I'll pass this along to the guys in the shop as a reminder. Checking pressure is one of the things done before recommending a replacement cooling unit or fridge, but I know sometimes somebody gets in a hurry, and skips it.
Old 07-05-2015, 06:40 AM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
Mine wasn't cooling well on gas. Fortunately, my fridge had a gauge. I noticed the pressure wasn't high enough. I adjusted the regulator and she cools great now.
CRH is online now   Reply With Quote
Old 07-05-2015, 06:51 AM   #7
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Thanks for the post, good reminder to check the pressure.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 07-05-2015, 06:55 AM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I suspect this is fairly common and most folks aren't aware of it. We took our Airstream to Jackson Center Service just before the two year warranty expired to have a multi-point inspection done. They found slightly low gas pressure and adjusted the regulator. After that she noticed our range burners and oven were easier to light.
Doug and Cheryl
Old 07-05-2015, 07:11 AM   #9
dznf0g's Avatar
Oswego , Illinois
Mine was only at 9" static when I checked it last year. Spec is 11" with all gas appliances on.
-Rich-
Old 07-05-2015, 08:58 AM   #10
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
11" WC is the key to cold fridges!
Old 07-05-2015, 10:15 AM   #11
1974 Argosy 20
Kooskia , Idaho
I have suspected that for a long time but fortunately have never had it happen to me.
Mostly I have run into rust from the boiler tube falling down into the burner and clogging it. Judging the heat output of the burner from looking at the flame is difficult. You can tell if it is blue, not yellowed, but as you report, the size and length of the flame can be off and you do not know it is wrong.
Old 07-06-2015, 07:04 PM   #12
lewster's Avatar
Naples, FL , Hood River, OR
Actually, the pressure spec. for LP is 11" water gauge (they stopped using water column, or WC as it is too easy to confuse it with the WC marked on LP tanks) with 50% of the appliances on. That was the last RVIA specification that I am aware of.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 07-06-2015, 07:10 PM   #13
dznf0g's Avatar
Oswego , Illinois
But what many miss is that the 11" spec is not static pressure but dynamic pressure.
-Rich-
Old 07-06-2015, 10:37 PM   #14
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Learned something new. Had I not read this I would have set at 11" static. Thanks!
My trailers are 16 and 17 years old. I assume they both have the original regulators, so I should be installing new regulators and flexible hoses soon.
The furnace, water heater, oven/range, and fridge could be on simultaneously in my trailers. One trailer has a quick connect for a grill or portable fire pit, but I hardly every use those. So should I assume the quick connect would account for no additional propane flow for this measurement or should I assume the largest appliance that might be connected?
Am I correct in assuming you are saying 50% of the maximum BTU rate, of all appliances combined, should be operating/burning, with a dynamic pressure adjusted to ~11" on the water gauge? When checking regulator pressure, which combination of appliances would you suggest should be operated during the pressure test, to represent 50% of the appliances.
Should the static pressure with no flow be slightly higher than 11"? (how much is to much)
Alan
Discovery Channel-Monster House Sneakinup Our Community 16 01-20-2005 07:53 PM
Replacing Carpet - Bizarre Discovery - ??? mdeneen Floor Finishes 15 10-13-2004 12:36 PM
Trailer size for a 2003 Land Rover Discovery runyandm Tow Vehicles 5 10-30-2003 09:09 PM
Land Rover Discovery to tow Bambi '62 Rosemary Tow Vehicles 10 10-20-2003 08:33 PM
Now comes the next fun phase: discovery. jpurdy General Motorhome Topics 3 02-16-2003 06:39 PM
