Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 07-23-2009, 08:45 AM   #1
Profile:  1970 27' Overlander
Columbus , Ohio
Checking for LP leaks
ok so I am new to this and finding my refurb of my 1970 overlander to be a bit more than expected. Just finished re-doing all the plumbing with PEX after finding many splits within the copper water lines.
My next challenge is with the LP. Would like advice from friendly community on the following:
- Checking for leaks. I want to check the connections as well as the lines (make sure there are no splits within a line). Is the liquid spray-on the best method to do this? Or one of those hand-held detectors?
- I currently have the lines running the Hot Water heater, oven, furnace, stove, refiridge... etc. The refridgerator has been replaced and is electric only. I don't plan on using the Hot Water or oven.. Should I be looking to cap lines that I don't plan to use and just leave them in place? I guess its a question of making the LP system as simple as possible (feeding only what I intend to use) in hopes that decreases potental problems. This may not make sense. Thoughts? The airstream will be parked once its done refurbed and will be stationary, not hauled around.
Thank you to everyone in advance for taking the time out to give me advise. I wish I had more time to just rebuild this camper completely, it sure is fun working on it.
cweinman is offline   Reply With Quote
Old 07-23-2009, 09:47 AM   #2
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Soapy water (bubble blowing liquid from a kid's store) will do just fine. You can also turn-off the LP supply and see how long it takes the flag to pop up. That will give you an overall system test. You can get a gauge that goes in the supply line to test for leaks also. These last two methods will tell you if you have a leak, but not where it is. Use your nose and some soap to pin-point any. It is rumored that some people have checked for leaks with an open flame but their exact technique is unknown since they are no longer available for comment!
"Not all who are laudering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-23-2009, 10:13 AM   #3
DEITZ645's Avatar
Profile:  2006 30' Classic S/O
1987 34' Excella
Mohrsville , Pennsylvania
Images: 99
I've used dish soap / water solution and Windex to good effect when looking for propane leaks.
Carl, Elaine & Bailey Beagle
2006 30' Classic W Slide & Limited Package Katarina
1987 34' Excella 1000 Double Door Savannah
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
AIR #14487
WBCCI #7429
DEITZ645 is offline   Reply With Quote
Old 07-23-2009, 11:39 AM   #4
Silverhobby's Avatar
Profile:  1956 26' Cruiser/Overlander
1957 26' Overlander
1962 22' Flying Cloud
Vale , North Carolina
Just be sure the soap you use is not alkaline. Brass fittings don't like a caustic solution.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Checking In 69RoadRunner Member Introductions 4 01-18-2008 11:52 AM
Just Checking In Doogie521 Member Introductions 4 08-06-2007 07:52 PM
Checking the System utahredrock Plumbing - Systems & Fixtures 6 06-10-2007 08:16 AM
Checking TV antenna for leaks Dan S All Argosy Trailers 3 03-25-2007 01:16 PM
Just checking truebebeblue Repairing/Replacing Floor &/or Frame 3 02-07-2006 12:43 PM
