Old 02-23-2015, 10:51 AM   #1
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Changeover regulator help
54 Flying Cloud has what appears to be the original regulator - see attached pic. Not sure how the changeover/selector works. I have one tank which is empty and one which is not. There is a large knob on the front of the regulator. I think both tanks are currently "selected" because if I disconnect the empty tank and open the valve on the other tank propane comes out the disconnected line. If I leave both tanks connected but close the valve on the empty tank, propane flows to my appliances.
Questions:
1. How do I select only one tank?
2. Does this regulator have "auto changeover" capability?
3. If I decide to replace it, what model is recommended?
I have already bought aluminum tanks to replace the rusty steel ones
BambiTex is offline   Reply With Quote
Old 02-23-2015, 11:13 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Personally I think a new regulator is a worthwhile investment of $30-$40 and lets you have a straightforward changeover mechanism. If it were an auto-switching regulator, the empty side should close when it switches so you can refill the empty tank without shutting off your systems, though I would select the full cylinder as the primary before disconnecting the empty one.
The regulator on mine was probably less than 10 years old when I bought the trailer, and it didn't provide sufficient gas pressure for the fridge to stay lit while traveling. While troubleshooting that I bought a water manometer to check the gas pressure at the appliances and it was low (less than 9" of water when a minimum of 11" is specified) so I swapped out the regulator for a newer one and haven't had any problems with that since.
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | Il Progetto ó 1976 Argosy 28 Center Bath | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
DKB_SATX is online now   Reply With Quote
Old 02-23-2015, 11:45 AM   #3
1974 Argosy 20
Kooskia , Idaho
My experience is that regulators last about 20 years max, then it is time to replace them. I would not mess with the one you have if I were you.
Old 02-23-2015, 11:56 AM   #4
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Looking at replacements.
Camco?
Marshall?
Cavagna?
Old 02-23-2015, 11:59 AM   #5
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Cavagna
Lance
Top is offline   Reply With Quote
Thermostat changeover? carver 1 Electrical - Systems, Generators, Batteries & Solar 3 04-29-2014 02:18 PM
2 stage automatic/changeover lp regulator woes Roothawg LP Gas, Piping, Tanks & Regulators 7 03-17-2012 06:54 PM
Automatic Changeover Regulator 66Overlander LP Gas, Piping, Tanks & Regulators 50 10-10-2010 10:16 PM
LP Tank Remote Changeover Indicator Wayward LP Gas, Piping, Tanks & Regulators 1 09-17-2007 07:38 PM
254 Automatic Changeover Regulator Striperv LP Gas, Piping, Tanks & Regulators 11 07-26-2005 09:16 AM
