Old 08-29-2016, 01:29 PM   #1
JayleNBob's Avatar
2015 27' FB Eddie Bauer
Silvis , Illinois
Change to 40# LP Tanks?
I'm considering upgrading to twin 40lb LP tanks, has anybody out there done this? If so, will they fit inside the OEM LP tank cover without any modifications?
Any insights are greatly appreciated.
Thanks!
JayleNBob is offline   Reply With Quote
Old 08-29-2016, 07:48 PM   #2
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
They're taller so they will need a cover made for 40# tanks. You might also need to change the hold down clamp to accommodate the taller tanks. Mine will only hold 30's, or 20's with a spacer.
Gearheart is offline   Reply With Quote
Old 08-29-2016, 08:09 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I change from 30's to 40's on my Excella. The cover for the 30# tanks is about 4" to 5" to short now.
Alan
Old 09-02-2016, 09:08 AM   #4
JayleNBob's Avatar
Silvis , Illinois
Thanks for the feedback, it is greatly appreciated.
Some follow-up on the project: I have purchased 2-40# Worthington tanks from my local Menards store. They are slightly taller than 29 1/4 inches, but still fit inside my propane cover which is about 29.5 inches high, (exterior dimension). That said, I also purchased a new 36" piece of 1/2" - 13 all thread to replace the current rod, as well as a few extra 1/2" nuts for anchoring everything down. Needing only about 30" of the all thread rod, the extra 6" will either be removed or "stored" below the anchor nut of the tank holder plate. I will lock this in place with 1/2" nuts on both sides to prevent it from cranking out on its own.
Anyway, the project is nearly complete and I'm excited to replace the twin 20# tanks the previous owner left behind(that's another story for another time).
Thanks again,
JayleNBob
Old 09-02-2016, 10:42 AM   #5
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Thanks again,
JayleNBob
Pictures when you are done. I'm curious.
Family of 4 living, working & exploring the USA in our Airstream.
OUR BLOG | FACEBOOK | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 09-19-2016, 05:17 PM   #6
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Previous owner of our trailer got a deal on a pair of 40#ers. All he did was add a longer threaded rod and the cover looks a little short. No problem at my end. Works great
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 11-06-2016, 07:39 PM   #7
Would you be able to post pictures of the 30lb cover with 40lb tanks?
one_maverick is offline   Reply With Quote
Old 11-06-2016, 11:02 PM   #8
Some Guy
djarrett's Avatar
2018 28' Tommy Bahama
Nashville , Tennessee
How much extra weight did it add? I've considered aluminum tanks but they are pricey
The Jarretts
Nashville, Tennessee
2018 27' Tommy Bahama
2015 F250 TV-Petrol
WBCCI # 22342
djarrett is offline   Reply With Quote
Old 11-07-2016, 03:21 PM   #9
retired USA/USAF
2001 30' Excella
Sorry I can't post any PIX. Our trailer is visiting a friend in North Carolina at the moment and I won't be picking it up until mid-December. Throw an eyeball on your current tanks and cover and just picture the bottom of the cover raised about 4" to expose the very bottom of the tanks. That's what ours looks like and for the cost of a new cover I can live with it. Mine are aluminum 40's and replaced aluminum 30's. I have no idea of the weight difference however I suspect it's not a whole lot more than the gas volume weight difference.
Roger in NJ
TAC - NJ 18
Replacing water tanks, holding tanks & battery? AussieGirl 1956 - 1959 Flying Cloud 57 10-19-2014 09:21 AM
Holding tanks gage is there a key or plugin to test the levels of the tanks. Buckshot 1999 Safari 1 08-18-2014 09:25 PM
20lb tanks vs 30lb tanks? AldeanFan LP Gas, Piping, Tanks & Regulators 5 04-05-2014 01:37 PM
'Convert' from 30# tanks to 40# tanks HeavyAssault LP Gas, Piping, Tanks & Regulators 19 11-28-2013 12:42 PM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 09:34 AM
